![]() | Home > Maintenance & Mods (L405) > Adaptive Cruise Retrofit to 2014 L405 Vogue |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
Microcat shows that all engine versions of the L405 only require the radar unit (LR043725 unless superseded) whereas petrol-engined L322s use a 2nd radar unit and an ACC ecu. A radar mounting bracket (LR033405) would be required as would the ACC version of the RH steering wheel switch (LR037452) then the CCF edited to change to CC to ACC with stop/go. The radar unit then has to be set to calibrate mode so perhaps a LR dealer can do that or if the IIDtool doesn't yet support L405 ACC calibration then ask GAP if they will do it, as was done for my retro-fitting to my L322.
pherplexed Member Since: 27 Apr 2010 Location: SC, USA Posts: 69 ![]() ![]() |
Resurrecting this thread b/c I'm the proud new owner of a 2016 Supercharged V8 and the adaptive cruise control is the only option missing that I'd love to retrofit.
Yes, that's my conclusion from studying the late 2012 version of Microcat which includes the MY13 L405. |
Really want to try this so did some more digging. If I ordered and installed the parts, could an independent LR mechanic access / edit the necessary CCF file(s) to enable ACC and do the calibration or does that have to be done at the dealer? 2021 P525 | Eiger Gray |
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 491 ![]() ![]() ![]() |
I’m interested in this one too. Guess we just need to know what parts to order, costs and installation requirements 2017 Range Rover Vogue V6 Diesel
Looks like the parts list is pretty straightforward, but pricey (about $2,300 for parts):
LR060076 - Radar mounting bracket LR087486 - Steering Wheel Switch Pack I've chatted with the guys at Powerful UK in the comments of this video and it appears all L405's come with the notch already in the bumper for mounting the radar unit. All in all, the install doesn't look too complicated if you're handy: removing the bumper to install the radar unit (wiring harness is already there, per GraemeS's comments above); then swapping the existing steering wheel switch pack with the new one. Maybe 4-5 hours. Only thing I haven't been able to sort is who I can have update the CCF file to enable the system and calibrate it once installed. I don't want to go to the local dealer b/c they're terrible but I'm not sure if my local independent has the JLR computer equipment to do that sort of thing. 2021 P525 | Eiger Gray |
Are there any independents that could do the adaptive retrofit on an L405 in the UK? 2017 Range Rover Vogue V6 Diesel
Update on this: I was able to successfully retrofit this to my '16 L405 SC. Start to finish, a pretty simple 2 hour job.
725browning Member Since: 02 Sep 2019 Location: Northampton Posts: 73 ![]() ![]() ![]() |
Hi. Was The wiring harness in place from the factory ? Thanks. |
725browning – yes, the wiring harness and cutout in the frame were already there from the factory. 2021 P525 | Eiger Gray |
Thanks. I have a 2017 sdv8 vse that I have not managed to sell and I am considering keeping it and have a play. It's a high spec for a vse but lacks the adaptive and If I keep it I would try and get the front and rear light upgrade. I might try and source the parts and see if I can find an independent to install the adaptive. |
Summary for anyone who finds this thread later:
Ans Member Since: 02 Aug 2020 Location: Houston Posts: 1 ![]() ![]() ![]() |
This is super useful info!
Mark1107 Member Since: 20 Oct 2014 Location: Los Angeles Posts: 106 ![]() ![]() ![]() |
Ans
