Home > Technical (L322) > Second battery |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 |
I have In my 2010 tdv8 |
12th Oct 2020 5:41pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
Not fitted as original. Mine has a second battery fitted, can be very useful. DIY but pro. |
12th Oct 2020 6:20pm |
Billie Member Since: 12 Oct 2020 Location: south-west Posts: 49 |
Thanks for that, good to know mine is not on its own. I presume it is for the entertainment side of things. Would I be right in saying, if I remove the main battery I will not lose the codes |
13th Oct 2020 9:59am |
I can only speak for my 2004 but when changing the battery no codes etc lost at all. I presume it is the same for all years as I've never seen a post regarding a problem. |
13th Oct 2020 4:41pm |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 344 |
I would suggest it's "electrically unlikely" that removing the second battery would cause you to need to re-enter any codes, my logic being that the cars electrical systems are 12 volts and hence, the batteries must be wired in parallel.
13th Oct 2020 8:11pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
There are no audio codes sir... Left them things behind with the P38 |
13th Oct 2020 10:42pm |
"There are no audio codes sir... Left them things behind with the P38"
14th Oct 2020 8:33am |
