Home > Technical (L322) > Sudden brake fluid loss.
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Hi
Today i had sudden brake fluid loss and brake pedal was on the floor.
I added fluid but it was gone again.
I had big oil dirt on left front hose suspected that was the reason but after cleaning and testing there were no fluid there.
Any ideas?
 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #569325 9th Oct 2020 8:29pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Favourite place to leak are the rigid brake pipes running front to back in way of the left hand sill of the vehicle. May have to remove the plastic sill cover to see properly. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #569327 9th Oct 2020 8:54pm
umitbat
Thanks
I Will check tomorrow 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #569328 9th Oct 2020 9:17pm
And have a check on the steel pipes that run down the rear wishbones... BIG failure point!
Post #569338 9th Oct 2020 11:35pm
umitbat
I saw some dirt there too.
What i dont get is how front left had so much dirt. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #569346 10th Oct 2020 4:21am
umitbat
sold 06 td6 160k
Sold 03 td6 260k
Post #569357 10th Oct 2020 9:40am
It is shocking isn't it.
If you remove the plastic covers above the sidestep brackets you will probably find more horrors...
The plastic coating on the pipes degrades and lets in water, holding it there to help the pipes rust to nothing. I thought I just had surface rust, until removal, and the pipes just fell to pieces in my hands....
Make sure to replace with copper nickel / Cunifer... .
Post #569377 10th Oct 2020 1:44pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Yup sad but true.
I replaced all my hard lines earlier in the year, the originals were totally corroded away to powder. L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #569415 10th Oct 2020 7:53pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Did mine about 2 years ago as all the pipes were shot. Then after had a new rear hose metal coupling fail and was lucky to get to the garage to get it repaired !
Post #569599 12th Oct 2020 10:46am
umitbat
Exactly shocking.
Bent sections are more prone to dusting i guess.
While bending there may be micro scratches inside and outside.
Direct lines won't suffer rusting as these parts. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #569782 14th Oct 2020 8:03am
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
First I knew of my rusty front to rear pipes was when they burst during an emergency stop Shocked 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #570393 20th Oct 2020 1:40pm
