![]() | Home > Maintenance & Mods (L405) > Twin speed transfer case judder |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
With the "special" transfer box oil at around £28 per liter and you need 1.6 L per change then the £179 sounds very good value . I am always dubious about software update in a vehicle that was working fine before . Is the update being used to mask or hide another problem ? |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 ![]() ![]() ![]() |
The software update has something to do with the torque values in the transfer box I believe But wouldn’t be surprised if it was to mask something else 😂😂
pherplexed Member Since: 27 Apr 2010 Location: SC, USA Posts: 69 ![]() ![]() |
aljo – I had the exact same issue and my Indy mechanic performed the TSB for $150 USD (~£115) and the problem went away completely. Super simple job, had the car back within an hour. Highly recommend doing it! 2021 P525 | Eiger Gray |
yeah got it booked in at the local indy for next week |
Jim_m_kidd Member Since: 03 Oct 2012 Location: Yorkshire Posts: 69 ![]() ![]() |
I had this done two weeks ago, dealer did it under extended warranty! |
A year or so ago, ours started making thumping/ shuddering noise/ juddering at low speeds and in reverse. Recovered by LR recovery after Technician assessed the issue to be driveshaft related. Diagnosis was Transfer case:
Dealer refused to do it under extended warranty
