Home > Maintenance & Mods (L405) > Anyone - Cleaning out the drain plugs |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35360 |
6th Oct 2020 1:46pm |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 |
Nice work Stan, thanks for that.
6th Oct 2020 2:24pm |
i havnt had a blocked drain problem so i've not had the carpets up ..... ... - .- -.
6th Oct 2020 3:24pm |
nfm Member Since: 09 Apr 2019 Location: UK Posts: 19 |
Haven’t tried it myself but would rodding them with strimmer flex clear out the blockage? That was my plan when I tested mine for blockage (they were clear). |
6th Oct 2020 3:48pm |
Had a good chat with the owner of the garage tonight tbh, and think I'll just let them put new drains in. He thinks they are perished so probably just wasting my time.
6th Oct 2020 5:57pm |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
Why don’t you just give a good squirt of WD40, using the straw supplied with the can, down each drain tube. Way cheaper and less hassle than replacing the drain tubes.....
6th Oct 2020 6:24pm |
I did see a video of that. He reckoned they were likely corroded as its putting water into the headliner and down the C pillar. all smug in my new plug!
6th Oct 2020 9:11pm |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 |
So are these drain tubes made of metal that they would be corroded ?
6th Oct 2020 10:29pm |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 |
Does anyone have a diagram of the L322 with drain pipes/plugs they could share? RR Vogue 4.4 TDV8 - 11
7th Oct 2020 8:24am |
WaterloggedFFRR Member Since: 22 Feb 2022 Location: Louisiana Posts: 6 |
Get it sorted out, or you could lose your vehicle. Rust can get so bad that there is no way of repairing the drain or hose. The entire sunroof assembly frame would have to be replaced. This exact problem/damage totaled my 2014 ATB. Bad design flaw. The tip that the hose connects to will rust away to nothing inside the hose and continue working until it breaks off entirely.
22nd Feb 2022 12:59pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1499 |
Yikes!!!
6th Apr 2022 10:13am |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 382 |
I checked my sunroof drains over the weekend and found one blocked, and the other clear but I've no idea where the water goes to as none seemed to come out at the bottom. Carpets are not wet though. More investigation is requried...
30th Jan 2023 5:14pm |
Stan, no-one replied to my above remark re the Vogue TDV6 with fixed pano roof - obviously us lesser mortals have no roof drains to clog? Am I right in saying a few older vehicles have been written off due to corrosion caused by this, or is that an internet myth? Something folks should check regularly, anyway. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
30th Jan 2023 7:11pm |
WaterloggedFFRR seems to be suggesting that his 2014 was written off because of this. Current:
30th Jan 2023 8:46pm |
