Home > Maintenance & Mods (L405) > Anyone - Cleaning out the drain plugs
Page 1 of 3 123>
CUE99T
Has anyone got a view or instructions on cleaning out the drain plugs.....otherwise its 700 quid for me to get the garage to change them out for the water leak......
I reckon its just the time its sat on the driveway under the trees and blocked...... all smug in my new plug!
2021 Westminster Black D300
2013 Vogue SE - gone
Some Porsche Cayenne guff pretending to be a 4x4!!
2006 Vogue
2004 Vogue
2001 Vogue
Post #569016 6th Oct 2020 2:35pm
https://www.fullfatrr.com/gallery/albums/u...TION~0.pdf
extracted from the WM ...link is in the wiki.. ... - .- -.
Post #569019 6th Oct 2020 2:46pm
CUE99T
Nice work Stan, thanks for that.
I don't mind giving the garage the work, but thought I'd have a go at clearing them out first as its possibly just blockage.
I might take the carpets up at the doors, have you done that? I'll check the pdf link in case its in that also.
Cheers
Paul all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #569025 6th Oct 2020 3:24pm
i havnt had a blocked drain problem so i've not had the carpets up ..... ... - .- -.
Post #569033 6th Oct 2020 4:24pm
nfm
2008 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Haven’t tried it myself but would rodding them with strimmer flex clear out the blockage? That was my plan when I tested mine for blockage (they were clear).
Post #569037 6th Oct 2020 4:48pm
CUE99T
Had a good chat with the owner of the garage tonight tbh, and think I'll just let them put new drains in. He thinks they are perished so probably just wasting my time.
It needs a few other bits done to it, so will just get them to service it and do the batteries and discs and pads.....I'll get the right ones this time!! lol all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #569050 6th Oct 2020 6:57pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Why don’t you just give a good squirt of WD40, using the straw supplied with the can, down each drain tube. Way cheaper and less hassle than replacing the drain tubes.....
Jim
Post #569051 6th Oct 2020 7:24pm
CUE99T
I did see a video of that. He reckoned they were likely corroded as its putting water into the headliner and down the C pillar. all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #569063 6th Oct 2020 10:11pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
So are these drain tubes made of metal that they would be corroded ?
I thought they would just be some type of rubber ?
As mechanics first statement was the drains might just be perished.
To clear them out with flex rod would one do this from the lower end under the car ?
I can't see how one would get to the top at the back of the pano glass roof is this the way to do it.
Or could one just blow pressurised air through the lines from the bottom end?
Interesting post , great to know the fix, thanks for all the replies.
Post #569075 6th Oct 2020 11:29pm
jackie-o
Netherlands
Does anyone have a diagram of the L322 with drain pipes/plugs they could share? RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #569093 7th Oct 2020 9:24am
WaterloggedFFRR
United States 2015 Range Rover Autobiography 5.0 SC V8 Mariana Black
Get it sorted out, or you could lose your vehicle. Rust can get so bad that there is no way of repairing the drain or hose. The entire sunroof assembly frame would have to be replaced. This exact problem/damage totaled my 2014 ATB. Bad design flaw. The tip that the hose connects to will rust away to nothing inside the hose and continue working until it breaks off entirely.
Post #624413 22nd Feb 2022 1:59pm
Gremlin500
Shocked Yikes!!!
Scary Stuff!
Am I right in saying us lesser mortals with fixed pano roof don’t have to worry about such things?
(I’m paranoid enough about my TDV6 crankshaft snapping like a twig as it is! Confused )
One advantage of “Poverty Spec” Vogue is, there’s less to go wrong as the vehicle ages…………. Laughing “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #627907 6th Apr 2022 11:13am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I checked my sunroof drains over the weekend and found one blocked, and the other clear but I've no idea where the water goes to as none seemed to come out at the bottom. Carpets are not wet though. More investigation is requried...
I did find this, which I found quite useful:
 Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #655161 30th Jan 2023 6:14pm
Gremlin500
Stan, no-one replied to my above remark re the Vogue TDV6 with fixed pano roof - obviously us lesser mortals have no roof drains to clog?
Am I right in saying a few older vehicles have been written off due to corrosion caused by this, or is that an internet myth? Shocked
Something folks should check regularly, anyway. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #655177 30th Jan 2023 8:11pm
Zebedee
WaterloggedFFRR seems to be suggesting that his 2014 was written off because of this. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #655194 30th Jan 2023 9:46pm
Page 1 of 3 123>
