Home > Wheels & Tyres > Scrubbed outside all tyres>
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hey All
All four of my tyres but especially the fronts have scrubbed on the outside edge to the point just noticed cords on the front nearside, centre and inside of the tread over 4mm still and all good its just the last 4cm on the outside edges.
I have it booked in for 4 new tyres on Friday and 4 wheel alignment, anything else that could cause this?
Post #568983 5th Oct 2020 7:05pm
DrRob
Ensure all suspension bushes are ok or the adjustment will be worthless
Make sure they put it into Tight Tolerance Mode
Fill tank to at least 3/4 full iirc
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #568985 5th Oct 2020 7:33pm
mjdronfield
Mine had tyres on like that when I bought it, not to the cord but bald on the edges. Only thing is they were winter tyres, and when I went to a tyre place for an alignment he reckoned it wouldn't help, as the tyres are softer and the car is heavy. Said if folk press on they will wear like that over time. I was a bit sceptical. Put 4 new Pirelli’s on, the ones it had when new, not winter, and no issues years later.
I know your tyres prob not winter ones, but I was still surprised what happened.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #568986 5th Oct 2020 7:42pm
Fronts is usually enthusiastic cornering Whistle
Some tyres are more susceptible than others - on the L322 Conti's seemed the worst offender, although great on the L405.
Have the tyres been rotated at all, as wear on the rears is less common, though alignment might cause it.
Post #568987 5th Oct 2020 7:43pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
That sounds like the front tracking is out (toeing in) & the Fronts have been swapped with the backs, but as it's still out, they have worn the same way.
Very unusual for all four tyres to wear like that at the same time & sounds like its a long way out to wear down to the cords Shocked
When they carryout the alignment, the technician should spot any worn bushes.
Post #568989 5th Oct 2020 8:00pm
lighthouse
Thanks kine has cheap s**t ones that came on it when I brought it in march, so it could be cheap nasty tyres causing it, I have never heard of this make on there.
Post #568993 5th Oct 2020 8:25pm
lighthouse
Thanks all got four brand new Conti premium contact 6 going on Friday morning.
I might go round corners in an enthusiastic manner, might having something to do with the 500 ponies a heavy right foot Whistle Whistle Whistle
Post #568994 5th Oct 2020 8:28pm
