Home > Technical (L322) > 2006 RR L322 6SP ZF Gearbox Swap
Let me start this story by making it clear that I'm no gearbox expert! If we get a customer car with a gearbox issue, it gets diagnosed and we would then have the gearbox rebuild or replaced...
So, I have acquired a 2006 4.4 AJ V8 with a duff ZF 6SP gearbox! I asked everyone with any experience and they all said "there are many many variants! You'll never get the wrong variant to work! it has to be a matching 4.4 gearbox. Definitely NOT a 4.2SC variant" I couldn't/wouldn't justify spending the £2850 trade price for a new gearbox as the car has nearly 200k on the clock...
So, I duly found a 4.2 sport being broken with only 82000 miles and the breakers agreed on a price with the matching torque converter which was delivered a couple of days later...
Out came the duff unit which was full of Aluminium swarf! So I'm guessing the torque converter had self-destructed! In went the donor box and TC and it immediately went into limp mode BUT drove forward & backwards so i was making progress Neutral and then it dawned on me, so i took the mechatronics unit out and stripped it down and changed the black electrics part? valve block electronics??? Then voila! Gearbox working again! After removing the cooler & pipes and cleaning out everything, servicing it with a new filter/sump and new fluid. I then took it for a 40-mile test run and she's perfect!
So, IMHO the 6SP ZF mechanical parts are only told what to do by the TCU and the electronics pack/valve block.
Hope this helps someone in the future?
RRPhil, if you do read this thread? Id love to know your thoughts sir? Bow down Thumbs Up
Post #568338 29th Sep 2020 12:51am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Craig, That's really interesting & reassuring to know. Thumbs Up
Post #568346 29th Sep 2020 8:47am
Thumbs Up Thumbs Up Thumbs Up
Post #568380 29th Sep 2020 6:34pm
joncorry
United Kingdom 2002 Range Rover HSE 4.4 V8 Tangiers Orange
Pleasing to read, i've a juddery tc at the minute and my local garage suggested that I wait for the gearbox to go and get it changed then. My 3.6TDV8 is just over 150K and like Craig, there's no way I could justify putting a new gearbox in it so knowing there's an alternative is great - cheers!
Post #568984 5th Oct 2020 7:22pm
GGDR
excellent detective work Thumbs Up
. Cheers, Greg
Post #568990 5th Oct 2020 8:03pm
Thank you Thumbs Up
Post #568997 5th Oct 2020 9:57pm
Well, were a couple of hundred miles down and all is VERY WELL Wink Wink Wink
Post #570446 20th Oct 2020 11:01pm
verydisco
Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #570523 21st Oct 2020 5:06pm
francy
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
well done Thumbs Up
Post #570527 21st Oct 2020 5:16pm
