Home > Technical (L322) > Oil leak, oil in coolant, 4.4 TDV8
Baltic Blue
I just don’t remember seeing one on mine, but it’s a while since I was underneath and I can’t see it mentioned in the WM.
Post #568497 1st Oct 2020 11:13am
GraemeS
I should have looked-up the O-ring size before posting - BS611 Viton (2 required).
Post #568498 1st Oct 2020 11:37am
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Mike.
It does look “after market” as it’s much rustier than everything else (despite being coated in 15w30!)
And it’s a weird shape being so rectangular and seems to have been welded on - makes me think it’s something that they don’t want to make easy to remove (like a Tracker).
I’m wanting the car back even more now, so I can solve the mystery Smile
Post #568502 1st Oct 2020 1:49pm
Siftah
Have actually got some in the post already as I’d read the forum thread and figured they were worth having in the garage ready! Smile
Post #568503 1st Oct 2020 1:50pm
i'd be interested to know what that box is as well...
good spot Mike.. Wink ... - .- -.
Post #568506 1st Oct 2020 2:31pm
DrRob
Tracker or key safe??
Having no engine undertray covers shouts to me that someone has inspected it for an oil leak before....
Advanced Factors sell them. I bought a new one as I couldn't be arsed cleaning my oiled one off.
New gaskets and O rings needed (my guy changed the whole cooler unit to save time) plus multiple flushes of coolant Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #568508 1st Oct 2020 2:34pm
Baltic Blue
Rolling with laughter Either Greg or Nino will know if it standard.... they both polish theirs underneath once a week Very Happy G reg 2.5VM Vogue Portofino red 1991- 1999
Post #568509 1st Oct 2020 2:43pm
Siftah
I'll give you 3 to 1 on key safe, Tracker is evens Smile
It's done 83k, so I'm guessing it's probably been through a gasket before looking at the age/mileage people on the main oil cooler leaks thread were mentioning!
Post #568517 1st Oct 2020 4:37pm
Siftah
This is the sort of obsessive compulsive behaviour attention to detail I like about this forum Smile
Post #568519 1st Oct 2020 4:39pm
jackie-o
Netherlands
if you suspect the leak has been there for a while, then definitely have them check the EGR. Mine threw in the towel after 75k RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #568549 1st Oct 2020 9:27pm
mjdronfield
Found some pics from when mine had a leak. Always good for a chuckle..... 🤣😱
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #568615 2nd Oct 2020 1:23pm
Siftah
Interesting, you also have that odd little rectangular box, so it's presumably a standard thing! Smile
And wow, I feel better about the tiny amount of oil in the coolant on mine now, you looked to be practically running oil instead of coolant Smile
Post #568624 2nd Oct 2020 2:27pm
mjdronfield
Yeah..... amateur Rolling with laughter
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #568625 2nd Oct 2020 2:50pm
mjdronfield
I’m thinking its a harmonic balancer to take vibration out the subframe. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #568634 2nd Oct 2020 4:04pm
