![]() | Home > Technical (L405) > SDV6 or TDV6 |
Ross Brown Member Since: 16 Sep 2020 Location: Norwich Posts: 72 ![]() ![]() ![]() |
Hi Pld118.
This is the air box from the L320 sport isn't it? Well it is certainly the same as my old 62 plate red edition I had.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Ok chaps.
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
According to ebay its for the SDV6 (L405 / L494) and not a TDV6 - cant comment about an L320 Sport, Ross. all smug in my new plug!
I'd say you're right....and I'm no mechanic but I'd assume the box I posted a picture of is the double inlets for the sequential air use maybe? all smug in my new plug! 2021 Westminster Black D300 2013 Vogue SE - gone Some Porsche Cayenne guff pretending to be a 4x4!! 2006 Vogue 2004 Vogue 2001 Vogue |
Cheers for all the help on this guys |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2592 ![]() ![]() |
There’s nothing unusual about it - it’s a TDV6, the brakes became smaller for 14MY. |
Hi Phillip.
Probably because they retained the twin parallel engine for longer, but upped the map for more power before moving to the new setup after they did in the 405.
Unless I've missed something in the vast array of forum and online/ motor industry clues eez eez for years, from inception in 2012, the L405 in 3.0 diesel variant was "TDv6" only. The SDV6 variant for the L405 only came a few years later, as previously mentioned.
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 153 ![]() ![]() |
Looks like the same air box as my 2013 tdv6 210 bhp discovery 4, in fact same as the sdv6 255 bhp 2014 version I had for a while also. Not sure if this is any use, but probably generic item of the period. |
Cheers for the comments on here guys really appreciate it |
Yea this airbox set up was the previous generation of range rover, range rover sport, discovery etc.
Hi Guys.
