Home > Wheels & Tyres > Smallest wheel size possible on a MY12 L322? |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 146 |
Does the 275/55R20 fit in the spare well?
23rd Sep 2020 6:31am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2529 |
275/55R20 don't properly fit in the spare wheel well, with one side's plastic edge trimmed to allow the diameter, blocks in the bottom to prevent the tyre wedging itself in and the floor raised on 50mmx50mm sponge blocks whereas 31" are reported to fit normally.
23rd Sep 2020 8:04am |
I did see the Pirelli AT+ at a tyre dealer here in size 255/60R19(Amarok) but did not check the LI. 2012 TDV8 Vogue SE 4.4 |
23rd Sep 2020 12:16pm |
I haven't seen the AT+ isn't listed anywhere in the world in 255/60R19 although 255/60R18 and 265/60R18 are both available here. |
23rd Sep 2020 8:58pm |
OK Graeme,maybe a mistake,will check when there again? 2012 TDV8 Vogue SE 4.4 |
24th Sep 2020 6:18am |
Pirelli were going to produce the AT+ in 255/60R19 as they had issued a product code for it, along with several other LR and non-LR sizes, as listed by a US tyre outlet. However after a few months all the unreleased sizes disappeared from the tyre outlet's web-site. |
24th Sep 2020 7:01am |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
Now I know this may cause some raised eyebrows, but if you don't want lead weights nailed on the inside or outside of your rims then get hold of some ceramic airsoft beads and put 150 - 200g in each tyre.
24th Sep 2020 11:24am |
Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199 |
I can confirm beads do work. They are brilliant for large tyres |
26th Sep 2020 4:32pm |
Sorry Graeme you got it spot-on.Tyre guy confused the 18"v19" Pity though! 2012 TDV8 Vogue SE 4.4 |
14th Oct 2020 7:35am |
I'd have preferred the other answer! |
14th Oct 2020 9:22am |
Ha ha,agree 2012 TDV8 Vogue SE 4.4 |
14th Oct 2020 9:29am |
