![]() | Home > Technical (L322) > End of week one for my new s/c |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 ![]() ![]() |
1.dont know
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6729 ![]() ![]() ![]() |
Cheers Scarey, Number 1 is a puzzle. I've located the TMC unit and done a "quick" check of the connections, but I'll delve a bit deeper Number 3 is a puzzle, since it warns about ALL the tyre pressures? I was of the impression each wheel had its own sensor which fed to a central ECU. Can this mean that water's geting into all 4 sensors? As an engineer I'm struggling to accept that could be the cause, hence my suspicion that it's something common to all 4 sensors? cheers |
re number 3, maybe water ingress into one sensor affects the the other three or confuses the ecu into thinking there is a fault in all...
Sounds plausible! I guess I'll need to go around each wheel in turn and see which (f any) triggers the warning..... Might save me a few shillings of main dealer investigation time! ![]() |
1 other thing I forgot to mention was the bluetooth connection.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1513 ![]() ![]() |
Hi, re: the TPMS; in that case could it be related to the controller/receiver module?
Thanks for that, I'll get in touch with Wiggs and see what he can do to help!
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7937 ![]() ![]() ![]() |
1 - my mileage to service is displayed where the mileage reading normally is - not on the AV screen...... |
The Servis indicator on the LCD on your dash only counts down the last 1000 miles to Servis so you find your self just being paranoid until it starts and then hacked off at anticipating the cost of a Servis, it's all part of the RR experience .
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
Mine showed no indication of the next service until it was 1000 miles away and then said "Inspection service 03.2011" - but now that I have had the service, it shows "Inspection service 03.2012" on key position 1 every time... |
Sorry.maybe I misled you, what I meant was that when I turn the key to position 1 the display under the speedo shows what radio station I'm tuned to, not the service info. The fact that it doesn't appear until it's nearly due and makes me feel a bit more resassured, but like others say, 1,000 miles doesn't give a lot of warning! Got - 2017 SDV8 Autobiography in Loire Blue Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
I was having a senior moment anyway - it was my old car that did that - the pre '05 model with the BMW electronics used to show the mileage to next service for about 10 seconds when you turned it on. The newer car doesn't do this |
