![]() | Home > Technical (L405) > L405 SDV8 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
Probably - but maybe not |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
First of all check the fluid under the bonnet to make suer the system hasn’t sprung s leak, if your happy it hasn’t then its code reader time. If you are driving just be aware it will roll more in corners and bends, you may also have to force the suspension to normal drive height, foot on brake while stationary, then hold the switch in the up position for 5 seconds, it will then raise. Good luck sorting it. |
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
Thanks no leak thankfully but just got the icarsoft v2 as don' t want to risk another £400 GAP from Canada. Got the L322 version but no use! |
L322 version of what ? IID tool ? If so, I thought it was the same tool, you just need to pay the £40 or so for a second VIN but that it read the codes anyway..... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35482 ![]() ![]() |
probably not a bluetooth version i suspect... ... - .- -.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3866 ![]() ![]() ![]() |
Did I read somewhere about a pesky little wire that goes to the top of the strut that sometimes breaks - or am I a banana? Geoff |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7856 ![]() ![]() ![]() |
That’s the adaptive dampers.... not the anti roll bars.
Unless Iam mistaken the icarsoft v2 is not up to the job. Yes I have the non BT , wish otherwise or maybe a reasonable proposition. I cannot but wonder how restrictive the gap tool is and how much a gap LR hobby can cost! From what I can see its hydraulic pressure failure and possible aar pump failure. |
