Home > Technical (L405) > L405 SDV8
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
L405 SDV8
Had the FF 6 months now and impressed but like any love affair we now have a fault! Active anti roll suspension fault. Read all the posts but my question is the car safe to use on the motorway to get to indy?
Post #567356 18th Sep 2020 6:44am
Probably - but maybe not Confused
It depends on what the actual fault is - but AFAIK if there are yellow lights on the dash then you’re OK and red lights mean you’re not. It could just be a sensor, could be more.....
Maybe ring the Indy and ask their advice ?
Post #567357 18th Sep 2020 7:17am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
First of all check the fluid under the bonnet to make suer the system hasn’t sprung s leak, if your happy it hasn’t then its code reader time. If you are driving just be aware it will roll more in corners and bends, you may also have to force the suspension to normal drive height, foot on brake while stationary, then hold the switch in the up position for 5 seconds, it will then raise. Good luck sorting it.
Post #567364 18th Sep 2020 8:08am
bleeperman
Thanks no leak thankfully but just got the icarsoft v2 as don' t want to risk another £400 GAP from Canada. Got the L322 version but no use!
Post #567381 18th Sep 2020 10:57am
L322 version of what ? IID tool ?
If so, I thought it was the same tool, you just need to pay the £40 or so for a second VIN but that it read the codes anyway.....
Post #567383 18th Sep 2020 11:50am
probably not a bluetooth version i suspect... ... - .- -.
Post #567387 18th Sep 2020 12:47pm
supershuttle
Did I read somewhere about a pesky little wire that goes to the top of the strut that sometimes breaks - or am I a banana? Geoff
Post #567391 18th Sep 2020 1:27pm
mjdronfield
That’s the adaptive dampers.... not the anti roll bars.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #567393 18th Sep 2020 1:45pm
bleeperman
Unless Iam mistaken the icarsoft v2 is not up to the job. Yes I have the non BT , wish otherwise or maybe a reasonable proposition. I cannot but wonder how restrictive the gap tool is and how much a gap LR hobby can cost! From what I can see its hydraulic pressure failure and possible aar pump failure.
Post #567415 18th Sep 2020 7:22pm
