Home > Technical (L322) > Range Rover L322 2005 height Calibration
ChrisRRV
United Kingdom 2004 Range Rover Vogue 4.4 V8 Tonga Green
Just bumping this up
Tried to recalibrate my L322 today using Autel height calibration software that appears to work with my car.
When I got the menu option before entering in each wheel to arch heights the car went into full off road height automatically however it was showing as the middle selection on the toggle switch indicating normal road use.
Tried a couple of turns to reset autel software computer or to turn car off and on but it just kept going back to this height, computer said it should be in normal road height but it definitely wasn't but on the toggle switch it was.
Now I'm stuck at full off road height all the time with no errors in the dash
Drove 10 minutes down the road from my friends and get inactive air suspension
Now I can't lower it via the toggle
Heading up tomorrow night to try this again ... anyone any ideas on what's going on or tips?
Car was measuring 84cm front and 79cm rear all round when it was at the max height from bottom of alloy to top of wheel IIRC
Any help would be great as the cars like a barge at present to drive Sad
Also stock height on 20s would be greatly appreciated or are they the same values per previous page screenshot
Post #566997 13th Sep 2020 9:20pm
ChrisRRV
Anyone able to advise?
Post #567096 15th Sep 2020 8:30am
Chris, If you turn the ignition off and on, you should regain the ability to change height.
Most calibrations use the centre of the wheel to the bottom lip of the wing. From memory, in standard height, this is around 495mm at the front and about 10mm lower on the rear. Got - 2017 SDV8 Autobiography in Loire Blue
Post #567116 15th Sep 2020 9:30am
ChrisRRV
Legend .... thanks alot!
Post #567124 15th Sep 2020 9:58am
