Home > Technical (L322) > No KEY BATTERY LOW message?
kgeddes
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
My recently purchased 2008 TDV8 L322 came with two keys. One key would not lock/unlock the vehicle remotely but would manually and would start the engine with no ‘KEY BATTERY LOW’ message displayed. The other key (refurbished) worked as it should - all functions.
Today, after a 15 minute drive, the refurbished key would not unlock the vehicle remotely. It did manually and started the engine with no ‘KEY BATTERY LOW’ message. After a further 5 minute drive it was fine - all functions.
Anybody know why I’m not getting the ‘KEY BATTERY LOW’ message?
Anybody know if it’s possible to recharge the handset using, for example, an electric toothbrush charger or an Apple Watch charger?
Thanks......
Post #566932 12th Sep 2020 4:37pm
Weegie
The battery is charged when the key is in the ignition engine running. (Inductive charging)You appear to have had a low battery in the key which your running has charged sufficiently.
AFAIK only that era RR has that system. John
GAP iiD BT
Post #566935 12th Sep 2020 5:14pm
kgeddes
Thanks Weegie. I don’t understand why I don’t get the ‘KEY BATTERY LOW’ message? Any idea?
Post #566937 12th Sep 2020 5:23pm
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
I had exactly this a while back, for some reason one of my keys wouldn't unlock the door but would start the engine. Just had to resync all keys and all was well.
Procedure here: https://www.fullfatrr.com/forum/topic47293.html 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #566940 12th Sep 2020 5:48pm
kgeddes
Thanks Tugger, I’ll try re-syncing the keys....
Post #566967 12th Sep 2020 11:53pm
kgeddes
Success! Re-synced keys this morning, both working as they should.
Thanks for advice Thumbs Up
Post #566976 13th Sep 2020 8:10am
