![]() | Home > Technical (L322) > U0415-00 (AA) Invalid data received from ABS Module HELP!!! |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
Have you checked the ride heights are correct. |
Fur3rd Member Since: 27 Nov 2019 Location: Chesham Posts: 24 ![]() ![]() ![]() |
No i havent hows the best way to do this on live data again ? |
Two pics from IID showing low and high |
RRYorks Member Since: 13 Jan 2020 Location: Yorkshire Posts: 40 ![]() ![]() ![]() |
U Faults are usually cascaded down form another fault, are you sure there are no other faults? 2010 3.6 TDV8 |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1365 ![]() ![]() |
Was the battery disconnected at any point ?
thanks Fisha
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16288 ![]() ![]() ![]() |
Turning the steering from lock to lock negates the need to drive the car... If the car is driven then the steering angle sensor will collect all its relevant data from the drive therefore replacing the need to turn the steering from lock to lock sir... Worth mentioning this for future readers benefit ![]() |
U codes are meaningless and should be disregarded sir... If you start your car with a battery in 90% health then you will start getting U codes as the voltage drops when the starter motor is working... P codes are the important codes sir |
thank you all going to take bikes out with family tomorrow and will report back of any errors |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 427 ![]() ![]() |
I had this fault just yesterday after an aborted IID tool update of my 2011 4.4 TDV8's CCF file (attempting to turn on the fairy lights as DRL's - don't ask).
Just wanted to say big thanks to every one all sorted now had all the lights flag up this time and read code as steering angle, so re-calibrated and reset faults and did come back after a 50 miles drive |
