Home > Wheels & Tyres > L322 Spacers
sumshiftyguy
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
L322 Spacers
Something I've done to most cars I've owned is to fit spacers to give a slightly more aggressive stance. I appreciate they aren't too everyones taste. It seems most who have fitted them to their L322 have gone with 30mm on all corners however on measuring, I think a staggered 30mm rear/20mm front would give a better fit under the arches.
The problem is I'm struggling to find anyone online that sells 20mm for these cars. Has anyone here done this and can point me in the right direction please?
Post #566681 8th Sep 2020 10:49pm
Brian Considine
Personally, on any vehicle, especially heavy ones the only direction I would point you is away from spacers. 2003 Range Rover Vogue TD6
Post #566707 9th Sep 2020 9:20am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
20mm is not practical for spacers UNLESS you change the wheel studs in the hubs for 20mm longer ones - so that the spacer is truly a spacer, trapped between the wheel & hub & maintaining good thread engagement between the wheel nut & stud.
Nearly all Land Rover "spacers" are actually adapters, where the spacer is thick enough (ie 30 mmm min) to have wheel nuts inside the "spacer" to retain it to the hub. Separate standard wheel studs fitted to the spacer then are used to fasten the whel to the spacer.
If the spacer is less than 30mm , there isn't enough depth for the retaining nuts and a reasonable supporting wall thickness.
Some people fit 5mm or so spacers without extended studs, but it's not a good idea as thread engagement is reduced to levels that no car company or engineer would / should accept. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #566712 9th Sep 2020 10:25am
sumshiftyguy
Thanks for explaining Pawl, very helpful. I am definitely looking at hub centric spacers which is what you're describing so what you're saying does make sense though for previous cars I've fitted 20-25mm spacers. I suppose if it's not a common demand from RR owners, manufacturers wouldn't make them which may be why all I can find are 30mm.
Just can't decide whether 30mm on the front would be too much and leave the wheel protruding out from the arch.
Post #566738 9th Sep 2020 4:04pm
have a search for ' spacers'.......there are a few threads re this...
btw, leave the fronts as they are and just soace the rears, that's if you decide to after reading those threads... ... - .- -.
Post #566743 9th Sep 2020 5:36pm
mjdronfield
I’m not sure what the guys with the Range Racer have done.
https://sites.google.com/view/the-range-racer/home
They could have used spacers, or you could get this look with a different wheel.....?
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #566745 9th Sep 2020 5:59pm
they're not OE wheels so they must have a different offset . ... - .- -.
Post #566750 9th Sep 2020 8:06pm
mjdronfield
Yeah, think they might be from an X5. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #566752 9th Sep 2020 8:26pm
sumshiftyguy
They look great!
I had a search on 'spacers' - didn't see any posts about catastrophe unless it's lurking in a thread with an unrelated heading.
K did see mention of 25mm being available but alas the post didn't mention where from.
I'll continue to think on it. Hopefully if anyone has fitted, even if 30mm all around, they could post some photos and some experience of running them it would be a great help.
Post #566757 9th Sep 2020 9:32pm
Mr Tee
the range racer lads are engineers with JLR, there's a full thread over on pistonheads, worthy of a search there.
Post #566765 10th Sep 2020 7:16am
mjdronfield
https://www.pistonheads.com/gassing/topic....00&i=0
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #566771 10th Sep 2020 8:19am
sumshiftyguy
Excellent, thank you!
Post #566773 10th Sep 2020 8:51am
LT
If you’re on Facebook their page is worth following:
Post #566778 10th Sep 2020 10:33am
sumshiftyguy
I am following them on FB but the PH thread is a good read so far.
I see early on in the thread that they have indeed gone with X5 wheels, which look great and set the stance off perfectly in my opinion. Unfortunately not a viable solution for me as I've just bought replacement wheels for my L322 as the ones it came with were severely corroded. I found some in the exact same style just with a slightly different finish. So my spacer question remains....
Post #566779 10th Sep 2020 10:46am
LT
I’d never fit spacers to such a heavy vehicle. In my opinion the potential cons far outweigh the pros (slight visual improvement).
If you do decide to fit spacers, I’d heed the advice above about thread length etc. Thumbs Up
Post #566780 10th Sep 2020 10:52am
