![]() | Home > Wheels & Tyres > L322 Spacers |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
Don’t do spacers I’m pretty sure your insurance company won’t cover it on such a heavy car. I would suggest if you want an aggressive stance buy wheels with a different offset.
LT Member Since: 13 Mar 2017 Location: South West Posts: 414 ![]() ![]() ![]() |
Yes, spacers would be considered a modification and need to be declared. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7907 ![]() ![]() ![]() |
Just more of a general query..... Doesn’t adding spacers put more load on the wheel bearings due to extra width/leverage or have things moved on from the days of the Ford Cortina?
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 705 ![]() ![]() ![]() |
Yes, it does increase the load on the wheel bearings - exactly the same for increased offset wheels that achieve the same visual effect. End result is reduced bearing life, but probably no big deal compared to the already woeful life of the standard suspension ball joints & rubber bushes. Paul, 2001 Discovery 2 TD5, 211,000 miles & climbing 2006 FFRR TDV8 Vogue 151,000 miles & now sold Member of Midland (Land) Rover Owners Club, www.mroc.co.uk |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1296 ![]() ![]() ![]() |
Hi Paul, I agree with you one hundred percent about the life of the suspension joints and bushes. My thoughts are that they can't be made too stiff [bushes] because of the large articulation they can go through when off road. Far more movement than a conventional car even though most of our cars never see that movement in normal use. I was amazed how much the suspension 'hung' the first time I jacked my car up to remove a wheel. I had to get a taller jack. Lol. |
