![]() | Home > Maintenance & Mods (L322) > Spongy Brakes - SORTED |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
Thanks Pete, will report back with pictures
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 ![]() ![]() ![]() |
Scot, I understand that home bleeding the brakes is a daunting task but,
Thanks Rich, fairly confident to do the job (thanks to everyones advice here)
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
check my post on the brake system flush, it is easy and straightforward provided you have vacuum pump. feeder bottle is essential as it will give you 1/2 liter of extra fluid so not to pull air into the system.
Thanks Nino.. this is very useful.
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 503 ![]() ![]() ![]() |
As soon as I undid a fitting I quickly screwed one of my homemade blanking plugs (see below) into the fitting. This prevented backflow of air bubbles and dirty fluid along the brake line.
This is super useful Pete.. thank you Current:
Ok.. so took about 6 hours.. both rear pipes changed and all went to plan.. I have just bled the rears so far as it was getting dark..
Left rear, (ie furthest away from master cylinder)
Thanks Rich, this is what confuses me.. whilst the general rule is start from further way and finish at the nearest one to the Master Cylinder, RAVE suggests a different sequence.
The version of RAVE I have shows a completely difference sequence. I am assuming its for the earlier L322s.
UPDATE - All sorted now.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
top job well done |
Well done buddy, great result for you |
