Home > Maintenance & Mods (L405) > Engine Oil Level - Not Available [4.4 SDV8] |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 |
I have had mine fail twice and spent around $ 4500 dollars .
5th Sep 2020 12:47am |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 771 |
Could grass cutting wire be used? Being yellow or red, maybe it would be easier to read, also to mark a level on it... |
5th Sep 2020 5:57am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8515 |
I would imagine it would. If it was a thicker one. There is nothing that can't be fixed with a hammer😜😜
5th Sep 2020 8:03am |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 379 |
I've not tried strimmer wire, and will give it a go.
5th Sep 2020 9:38am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Jlr should sack the 'engineer' who came up with this idea and the person who gave it the go ahead.
5th Sep 2020 10:05am |
Update:
8th Oct 2020 12:59pm |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 286 |
My new (to me) 2013 SDV8 is going in to the garage shortly to have this fixed. Thankfully it's still under warranty. However, I would be interested in your "dipstick" for future use as I would not like to be picking up the bill for this.
8th Oct 2020 1:15pm |
TJRL Member Since: 07 Sep 2019 Location: Reading Posts: 198 |
Would this also work on the L322 4.4 TDV8? 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD
9th Oct 2020 12:39pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3766 |
TJRL,
9th Oct 2020 2:19pm |
Remove it when not in use.
9th Oct 2020 5:50pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Zebadee, if you want to make me one and ill check all the 405's/322's that come through the workshop? Would that help? |
9th Oct 2020 10:41pm |
Craig - that would be brilliant. Thanks.
10th Oct 2020 7:15am |
Chris thegasman Member Since: 01 Oct 2021 Location: Midlands Posts: 2 |
Did this the other day with base guitar wire as advised works fine and as I guide we found that the level of oil when full was almost the same as the width side to side of the air box so an easy visual check if you haven’t got a tape measure
2nd Oct 2021 3:44pm |
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 139 |
How would one use this checking method on an L322. ? where for instance is the 'entry tube' to shove the wire down ?
24th Feb 2022 10:17pm |
