![]() | Home > General > L322 Pre-purchase Inspection |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
There are a few specialists around the area you quoted. Keith Gott, AJ LandRover, Mark West etc.
nfm Member Since: 09 Apr 2019 Location: UK Posts: 19 ![]() ![]() |
Using google I would source a local RR specialist and call them to agree approach. When I distance bought mine I agreed a verbal report following a one hour test drive/ramps inspection for the cost of one hour of labour. A bargain. |
How are you getting on? Another new member in Hampshire was also looking recently
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 ![]() ![]() ![]() |
I too are on the search for a good 2011/12 l322 while I feel independent inspections are a worth while investment ideally if I was to use one I would also want one who has software that can ready the Ecu's.
Agreed. In my case as part of the inspection they used the code reader to check/clear all codes, then took it for a good run and checked again for what came up. |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 254 ![]() ![]() ![]() |
Apologies for the radio silence - emergency appendectomy delayed my research somewhat! At least Covid ensured that A&E was deserted! Thanks for the replies, I'm now back in action and hopefully viewing a 4.4tdv8 later this week. 81,000m - a risky mileage from what I have read? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Starters and alternators seem to go around 80k miles
Glad you're on the mend! PM replied to Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Bought mine with 86k i wouldn't be too worried about the milage check the history and have a good inspection, check for plumes of smoke when giving it some to the red line.
Unusual to see a main dealer with an L322 - I thought 5 years was normally their age limit?
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 331 ![]() ![]() |
duplicate |
Glad you've recovered!
Thanks - test drive tomorrow! |
Looks a peach but check the usual things = oil cooler leaks, arches / sills, smoke screen on booting etc
