Home > Technical (L322) > L322 2012 Clunking sound |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
I think mine needs doing as well, getting rumble from centre of the car when under constant load or under acceleration.
3rd Sep 2020 9:44am |
Mousey Member Since: 22 Mar 2020 Location: Leicestershire Posts: 20 |
I got mine from Propshaft Technix on eBay, £35 del. |
3rd Sep 2020 10:27am |
There seems to be some confusion some quote 02 - 09 and some 02 - 12 mines an 11, but guessing they are all the same anyone know? |
3rd Sep 2020 11:36am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
When I did mine I had the prop refurbed with new ends made a real difference |
3rd Sep 2020 5:32pm |
LR Parts sell the entire shaft including the bearing for 271 plus vat, wondering if its worth / easier to swap the whole thing, they also sell the bearing for 22 +vat.
3rd Sep 2020 6:19pm |
I think I will just buy the whole shaft then, that will make it quite a simple job. |
4th Sep 2020 9:22am |
Hardest bit will be taking exhaust off or trying to get the heat shields out without destroying them. |
4th Sep 2020 9:54am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 419 |
I don't know the definitive answer as to whether rear prop centre bearings can be replaced seperately on post 2007 cars - But I'd like to know myself now!
4th Sep 2020 11:26am |
Mine is 2012 and I managed to obtain and fit the center bearing! only issue was rust in the center spline which made splitting difficult. |
5th Sep 2020 7:50am |
That's good info, thanks! 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
5th Sep 2020 8:41am |
