Home > Technical (L322) > Rust |
Bloke Member Since: 13 May 2019 Location: On the road to Oban Posts: 120 |
Came over all tight and decided to have a go myself. Sill was filled with waxoyl. Zinc primer for now, top coat to follow.
1st Sep 2020 5:51pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Just an aside to all these problems with rust forming at the rear of the cills behind the covers.
1st Sep 2020 6:18pm |
That's a top tip fella. Will give it a go. Thanks. Perfect night for spray painting here, zero wind, so just been out and flashed over the primer with top coat, just before bad light stops play.... |
1st Sep 2020 6:55pm |
mark towill Member Since: 27 Aug 2020 Location: calgary Posts: 19 |
I think I will try the Gorilla tape tip. I have gotten quite good at removing the plastic sills, however not so good at lining up those clips and retrieving them when they fall in the sill |
2nd Sep 2020 2:54am |
Ordered a pair of Freelander 2 wheel arch protectors as suggested somewhere on here, thanks.
2nd Sep 2020 11:25am |
Cill is looking much better. Glad I got some top coat on last night as rain stops play today....
2nd Sep 2020 11:36am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 518 |
Now you're just showing me up! Can I buy it back?
3rd Sep 2020 6:11pm |
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 |
Had my long waited appointment at a local blasting shop. They did cleaning of the rust at the whole
3rd Sep 2020 7:09pm |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 602 |
WOW That is some protection job |
3rd Sep 2020 7:55pm |
