Home > Technical (L322) > Fuel Injection System error after changing in tank fuel pump |
mazza7282 Member Since: 10 May 2020 Location: Essex Posts: 99 |
One thing I forgot to mention is the high pressure pump has been replaced in the past but the looks of it, looks cleaner than the rest of the components.
29th Aug 2020 7:46am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
If you unplug the sensor ontop the fuel filter, the low-pressure sensor, you should get an instant error on dash and bong of doom 2007 TDV8 VSE
29th Aug 2020 1:16pm |
Bong of doom is already present the minute you put the key in the ignition and turn thr key to position 2. Comes up with “fuel injection system” error before the car is even running. I wonder if ive still got the old one i replaced somewhere ...... or did I bin it. |
29th Aug 2020 4:27pm |
So I guess I binned by old fuel pressure sensor, couldn't find it anywhere
1st Sep 2020 2:25pm |
Good to hear you found the problem. 2007 TDV8 VSE
3rd Sep 2020 12:33am |
