Home > Technical (L322) > Fuel Injection System error after changing in tank fuel pump
mazza7282
United Kingdom 2003 Range Rover SE Td6 Adriatic Blue
I've read across various posts relating to the TD6 in tank fuel pump.
Bit of background: - car was purchased as non runner, inline fuel pump, diesel filter and fuel pressure switch made the car a runner again...yay !. But when the tank would get to less than 1/4 a tank the vehicle would cut out. I have been treating 1/4 a tank as empty since then for a few months now and living with it.
During the initial diagnosis of mine, I have had the entire fuel system tested at a fuel injection specialist, leak off test, all fuel pressures monitoring during a drive as I don't have that equipment myself.
I know the high pressure fuel pump has been changed in the past (however I can't confirm the condition of it of course, looks newer than the rest of the bits on the vehicle)
Now ...........it's getting worse, as the vehicle would start to cut out at just over 1/4 a tank now.
See video -
So got myself a brand new in tank fuel pump & sender, as the kit came with the left hand fuel sender I swapped that out as well. There wasn't any accompaniments in the tank (we'll only a few small bits) but I drained and disposed of 15 litres of diesel Sad
I haven't checked the wiki, but if there isn't a write up in there for how to replace this, i'll write one up with a few pictures.
Job took a few hours as I was faffing (including the drain). I re-added 10 litres of fresh diesel, 5 litres in the left hand tank as I had access, and 5 litres in the right side, via the filler cap.
The minute I re-attached the battery and turned the key to position 2 to let it prime, I got the "fuel injection system" error on the dash, without even starting the car. I checked for leaks around my work and there were none.
I started the car and it started with no issues, I rev'd the vehicle a bit and checked the connections for leaks again.
Took the car for a test drive and I still saw "fuel injection system" error, yet the car drove fine.
I did note that when I put my foot down, the message would go away I can only assume that fuel pressure had returned to normal, but then when I removed my foot from the accelerator the message would come back again but the car still drove fine, I put another 20 litres of diesel in it, fuel gauge crept up to 1/2 a tank.
Before I take the car back to the fuel injection specialist to perform some more checks, is there anything I might have forgotten to do during the re-fit ?
Here's whats happening now during normal drivin (error message displayed) and putting my foot down under hard acceleration the message goes away.
Thanks
Post #565232 23rd Aug 2020 9:55am
wayneg
You get the fuel injection system error warning from the sender ontop the fuel filter if you are not getting enough pressure around 3 bar, it should if healthy be closer to 4bar. If you are sure the tank pump is good I would be looking at the external one. There is a good video how-to on youtube for the in tank sender unit, it's on a V8 but I followed it to change just the pump in mine
https://www.youtube.com/watch?v=YMWxPwgeLBQ&feature=youtu.be 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #565248 23rd Aug 2020 12:49pm
mazza7282
Hey
Thanks for the reply, as noted in the initial thread.Ive just changed this as it was faulty. The new one uses a bosch motor so i know its a quality part.
The old one is currently waiting to go the tidy tip.
The pressure sensor on top the diesel filter, i changed that a few months ago with a britpart one so it should be reading correctly (was getting air bubbles in the clear pipe)
I have however noticed that the feeder pipe to the high pressure pump has started leaking since this morning, wasnt doing that yesterday.
Either way, I cut off the Censored rubber bits off the pipe and re attached on bith sides of the high pressure pump.
Its no longer leaking (i think now the in tank pump is sending higher pressure it must now have been leaking past the weaker part of the pipe)
Started the car and it went away for a few minutes, but then came back again
Post #565258 23rd Aug 2020 2:36pm
wayneg
The low-pressure pipes to the high-pressure pump are a common leak point and as you have done a quick fix. There is always a chance of a faulty new pump however I would be checking the pump relay in the back fusebox and the relay in the ECU box at the front. Also the wiring/plug on the external pump. The pump in the Tank is a lift pump the external pump provides the 4bar pressure to the high-pressure pump. When my Tank pump started to fail, when I floored the car at speed it just bogged down as if it was running out of fuel, otherwise drove fine with no warnings. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #565311 24th Aug 2020 12:26am
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
Following this thread as I've had similar issues in the past and thinking about replacing in-tank pump. Now with working from home, I've got plenty of time to mess around with the car. 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #565325 24th Aug 2020 10:30am
mazza7282
Aside from the in-line pump change today, I have been using the car some of the day with less than 1/4 a tank and the car would have cut out several times by now, hence why I changed the in tank pump as the problem appeared to be getting worse as it started to cut out at between 1/4 and 1/2.
Could you advise how the fuel pump relays could be causing an issue ? As I would have thought the car would have cut out/not start at all if the relay was at fault, the same with the in line fuel pump wiring being a bit dodgy.
The feed pipes going into the high pressure side, I just happen to notice whilst looking around the vehicle. Luckily that didn't take too long to resolve.I had hoped that because of the small leak in that area, it would have been responsible for the potential lack in fuel pressure.
I decided to remove the secondary/in line fuel pump and the only thing I noticed was the electrical connector was covered in diesel, I had removed the electrical connector second to removing "in" fuel line, so there shouldn't have been any diesel dropped on the connector as I hadn't removed the "out" fuel line at that point. It was a good make of pump, had a Delphi sticker on it.
The in-line pump is newish as I suspected, all the clips were jubilee clips with the nut and bolt setup. I decided to tank a punt and just swap out the in line fuel pump anyway. I fitted a bosch one at the cost of £108.
After reading the RAVE workshop manual it states that excessive fuel pressure dispersed via the pressure relief valve on the common rail from memory
Heres a similar video, so the one I attached to the beginning of the thread, showing the same thing but stationary.
This thead on FFRR was very informative too,
https://www.fullfatrr.com/forum/post365332.html
I guess I do need the pressures read in more detail
Post #565380 24th Aug 2020 5:50pm
mazza7282
Basically why I did it, as I've been WFH too. TBH the car was purchased right at the beginning of COVID so its given me something to do as like you, when i'm done for the day. I'm already here.
Post #565381 24th Aug 2020 5:52pm
ShuntL322
United Kingdom 2002 Range Rover HSE Td6 Zambezi Silver
It’s a fiddly job. But could be worth pulling the regulator off the back of the high pressure pump and checking the o rings.
If the o rings spit then it allows more fuel back down the return line and not enough to the injectors.
It’s a pig to get at but it patience is key to removing it.
Fixed mine along with a set of injectors
Post #565428 25th Aug 2020 9:34am
mazza7282
You know that reminds me, i had a 1300 cdti corsa mant years ago.
It would start fine with easy start but not start on its own. The o ring failed exactly as you show there.
It didnt start on its own as it couldnt build up enough pressure in the fuel rail, so it was sending all of it down the return
Post #565442 25th Aug 2020 11:44am
ShuntL322
Yup. Same as this one. Easy start down it’s chuff would just give it enough to start. Ran like a bag of spanners with now power tho. But that could of been the fact 3 injectors where shot and both pumps tired too
Worth a look it’s only an hour so to strip it off. I got a replacement from an X5 at a scrap yard
Post #565447 25th Aug 2020 12:59pm
mazza7282
Yea, guess it would be worth a look.....but then as I said, runs, drives fine far as I can see.
Have I got yo remove the high pressure fuel pump to get to it ?
On my corsa it was at the end of the fuel rail but looking on line it looks like its on the side of the high pressure pump ?
I reacon ive now done 120 miles in this thing and it hasnt skipped a beat, all i see
is this stupid message !!
Ill let you guys know then in that case
Post #565592 26th Aug 2020 5:49pm
ShuntL322
It’s on the back of the HP pump but accessible without removing said pump. I think I took of the inlet manifold an injector pipes. I did have to use every extension I own and a lot of sweat words. But it is possible.
If you still getting a message then I’m guessing it still thinks there is still a fault. On mine the injector message went away once I cured it.
A good snap on reader will pull some codes an read the live values you need for fueling. Maybe easy to get hold of one of them locally
Post #565611 26th Aug 2020 8:51pm
mazza7282
Before I remove the fuel pressure reg on the side of the HPFP, I took the car to my guys down the road to plug it in, as my code readers didn't find anything, one of them only found the engine ECU and displayed no faults so I just chucked it back in the drawer, so I got them to plug it into their solus for me
Its come up with the following codes along with the message on the dash
P1260 - Delivery Fuel pressure monitoring
P1255 - Delivery fuel pressure sensor
So despite me changing the lift pump and external in line pump for (good measure) with bosch parts its still winging about fuel pressure.
Bear in mind I only changed the lift pump as it was cutting out at 1/4 tank and after having the entire car looked at a few months ago at a fuel injection specialist who advised i've probably got a dodgy tank pump (which I did)
I mean if the engine starts & drives fine and I can now run the car to the fuel light coming on (where i couldn't before) the only thing i can think of is : -
-I might have fouled one of the syphon tubes on the left side of the tank (i'll check that now, but i'm not hearing any additional wining noises coming from the pump just normal operation)
-i've got the wrong in line fuel pump <bosch> but the car was winging before that, so who knows it may have hag the wrong in line fuel pump all along
-Or one of these pressure sensors has failed (the one on the top of the fuel filter has already been changed) or it could be the rail pressure sensor
Struth !
Post #565748 28th Aug 2020 9:13am
ShuntL322
Live values of the pressure will help too. Think they want 3.5 to 4 bar at tickover. It was a solus I used to see that data which showed low pressure as it cranked. Once it got running the HP delivered plenty for it to run well by shear force. But cranking it where it showed up on live data.
Post #565753 28th Aug 2020 9:52am
mazza7282
Youre right, im Censored into the wind otherwise.
My code readers found nothing, hence why I drove it down the road. they dnt charge me anything for a quick read anyway but getting the pressures, id have to give em something ofcourse.
Ive decided im not convinced by the pressure reg at the side of the HPFP as the car starts n runs just fine so im gonne leave it for now.
I decided to double check my work and nothing is fouled or overtightened, i “carefully” took a vid of inside the tank on airplane mode, if it was petrol I never would have attempted this.
The pump hums and you can see the return feed tricke up the pump.
Just before the fuel filter, if only i had a guage lol. But it fills this 2 litre coke bottle in next
to no time, so im also convinced its working to spec.
Off to get the pressures read then ..........
Post #565801 28th Aug 2020 4:50pm
