![]() | Home > Technical (L322) > What is this? |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
Sorry, photo rotates 90 degrees when I post. Can’t figure out how to fix 😐 RR Vogue 4.4 TDV8 - 11
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85 ![]() ![]() ![]() |
I may be wrong but I think that part is also used on the BMW X5 rear subframe bush assembly and has a use on that car but not on the Range Rover. Happy to be corrected if someone knows different though.
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
are you referring to the hanging cable / pipe? it could be the abs cable come out of its plastic bracket
Just to be clear; I´m referring to the cable that is hanging down. Haven't seen it before and there isn't one on the other side?
@dexion7; aha, so just a matter of re-attaching it then?
