Home > Technical (L322) > Tdv8 3.6 dead turbos + more? |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 |
When my TDV8 lunched its turbos the service manager at Keith Gott said it’s common when a turbo fails that so much oil leaks past the turbo seals that the other turbo oil feed suffers oil starvation, causing that turbo to fail. Since you have one side leaking large amounts of oil into the intercooler (same as mine, there was loads in it), it’s quite conceivable that the other turbo will have suffered oil starvation. I didn’t bother to strip the turbos off mine as I stripped/scrapped it anyway, so cannot confirm exactly what occurred.
27th Aug 2020 10:44pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1779 |
That is exactly what happens, unfortunately |
28th Aug 2020 5:40am |
Slow Member Since: 09 May 2015 Location: Inverness Posts: 39 |
Mikey your name keeps popping up when I have been researching this.
28th Aug 2020 9:33am |
