Home > Technical (L322) > Adaptive dynamics fault after restricted performance
Gusfast
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
Hi,
Re: Dec 2009 (2010 facelift) 3.6.tdv8
I am hoping one of you fine people may be able to shed some light on my problem. I had a top intercooler hose split on me the other day and it went into restricted performance. One of the error messages was adaptive dynamic fault, which looking on the forum is a common.
The hose has been replaced but I still have the adaptive dynamic fault message. It doesn't always come on straight away. Sometimes it does, sometimes it comes on after a few metres, sometimes it might be a mile down the road.
Have checked the front shock wiring and no obvious problems.
My mechanic only had time to clear off any error codes this morning but hasn't made any difference. Will be going back in next week when he has time to investigate.
Anybody got any idea what could be the cause or where to first start looking? I haven't tried adjusting the ride height as I didn't want to potentially create another problem as at least it's drivable at the moment.
Thanks in advance for your help
Guy
[/list]
Post #565758 28th Aug 2020 10:38am
DrRob
Wiring on top of front struts usually. Use Search function and type in Adaptive Dynamics Thumbs Up
https://www.fullfatrr.com/forum/search.php Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #565759 28th Aug 2020 10:41am
Gusfast
Thanks.
Have already checked wiring and nothing obvious.
Just seems strange that everything was ok before the split hose causing the restricted performance and adaptive dynamic fault message.
Post #565760 28th Aug 2020 10:54am
DrRob
Checked rear wiring too? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #565781 28th Aug 2020 1:46pm
Gusfast
Not yet.
Can you please tell me where I need to start pulling up carpets?
many thanks
Post #565784 28th Aug 2020 2:02pm
DrRob
Lift out the boot floor cover and look in the two back corners near the rear seats. You'll see the wires Thumbs Up
Have you carried anything heavy in the boot recently? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #565785 28th Aug 2020 2:04pm
Gusfast
Thanks.
Nothing heavy carried but a few weeks ago my mechanic was going to change the rear dampners but I had got the wrong ones. I know he didn't remove the old ones but pretty sure the carpet came up.
Post #565786 28th Aug 2020 2:11pm
Gusfast
Just checked rear wiring - nothing obviously wrong!
Guess I'll just have to wait until next week when it can get plugged in and properly investigated.
Thanks for your help.
Post #565788 28th Aug 2020 2:32pm
Discotigger
When you lifted up the rear carpets, did you check the wiring that runs around the fuel tank? If you unbolt and lift off the two round access panels in the floor, that will give you a chance to check the wiring for the adaptive dynamics. It's the most common fault if the rear left or right AD loom is at fault as the wiring gets chafed by the tank and then eventually breaks. I had the same symptoms as you, intermittent AD fault which got worse, IID Tool showed Rear Right Sensor Ground Fault. The wire had got chafed then broke. Easy fix as you just need to splice a new bit of cable to join the break.
edit: If you lift out the Boot Floor Cover, fold the rear seats forward and lift up the carpet, you'll see the access covers, the fuel tank is under those two covers and the wiring runs around the tank You'll also need to lift the rear door trim pillars out of the way to lift the carpet and unbolt the seat locking brackets (torx driver needed for the bolts).
Hope this helps.
Post #565792 28th Aug 2020 3:35pm
Gusfast
Hi,
Thanks for the help.
I didn't have to lift the carpets as I only checked the wiring to the rear dampners, accessed from the boot.
Do you mean the access panels that you have to lift the rear seats and then lift the carpet to get to?
I had a new fuel pump and senders earlier in the year so if it's those there has been activity around there.
Post #565793 28th Aug 2020 3:43pm
Discotigger
Hi,
Yes you need to lift the carpet to get to the access covers, just edited my post to explain more.
Post #565794 28th Aug 2020 3:44pm
Gusfast
Thank you.
I haven't got a torx driver but will certainly be speaking to my mechanic to get checked out a.s.a.p
Still seems strange that it was fine before the hose split.
Once again thanks for your advice.
Post #565795 28th Aug 2020 3:53pm
Range
United Kingdom 2010 Range Rover Autobiography Black 5.0 SC V8 Java Black
Gusfast wrote:
Thanks.
I had this happen to me when my mechanic replaced my rear shock? it turned out he didnt check that the plug in top of shock should only be put in one way and bent the pins inside the connector so I had to with tweezers try and straighten up pins and plug connector in the correct way but after managing to do this all working fine again and it a instant fix the fault will automatically clear.
There was no way I was paying another £275 for another rear shock because the mechanic didnt plug a connector in the right way and bent the 2 tiny little pins inside?
Good luck you will need a bright flashlight to see inside by the way!! A Rangerover is for life not just for christmas
L322 5.0 Supercharged Autobiography - Black
L322 5.0 Supercharged Autobiography - Black - gone
L322 4.4 Vogue Green - gone
P38 4.6 Vogue Blue - gone
P38 4.6 HSE Grey - gone
P38 4.6 HSE Green - gone
P38 4.0 SE Blue - gone
Post #566036 1st Sep 2020 7:52am
GGDR
yeah the connectors are tiny
. Cheers, Greg
Post #566038 1st Sep 2020 8:06am
Gusfast
Thanks for the advice.
Is it just a case of pulling the connectors from the top and checking the pins?
Post #566091 2nd Sep 2020 5:43am
