![]() | Home > Technical (L322) > Adaptive dynamics fault after restricted performance |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
Wiring on top of front struts usually. Use Search function and type in Adaptive Dynamics |
Gusfast Member Since: 24 Jan 2017 Location: Somerset Posts: 35 ![]() ![]() ![]() |
Thanks.
Checked rear wiring too? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Not yet.
Lift out the boot floor cover and look in the two back corners near the rear seats. You'll see the wires |
Thanks.
Just checked rear wiring - nothing obviously wrong!
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
When you lifted up the rear carpets, did you check the wiring that runs around the fuel tank? If you unbolt and lift off the two round access panels in the floor, that will give you a chance to check the wiring for the adaptive dynamics. It's the most common fault if the rear left or right AD loom is at fault as the wiring gets chafed by the tank and then eventually breaks. I had the same symptoms as you, intermittent AD fault which got worse, IID Tool showed Rear Right Sensor Ground Fault. The wire had got chafed then broke. Easy fix as you just need to splice a new bit of cable to join the break.
Hi,
Hi,
Thank you.
Range Member Since: 07 Dec 2011 Location: London Posts: 8 ![]() ![]() ![]() |
I had this happen to me when my mechanic replaced my rear shock? it turned out he didnt check that the plug in top of shock should only be put in one way and bent the pins inside the connector so I had to with tweezers try and straighten up pins and plug connector in the correct way but after managing to do this all working fine again and it a instant fix the fault will automatically clear. There was no way I was paying another £275 for another rear shock because the mechanic didnt plug a connector in the right way and bent the 2 tiny little pins inside? Good luck you will need a bright flashlight to see inside by the way!! A Rangerover is for life not just for christmas L322 5.0 Supercharged Autobiography - Black L322 5.0 Supercharged Autobiography - Black - gone L322 4.4 Vogue Green - gone P38 4.6 Vogue Blue - gone P38 4.6 HSE Grey - gone P38 4.6 HSE Green - gone P38 4.0 SE Blue - gone |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
yeah the connectors are tiny
Thanks for the advice.
