Home > Maintenance & Mods (L322) > They say it happens with age...... |
I went out 5 days ago and could smell a slight bit of sweet antifreeze when I put the car away. Wandered out and thought I’d see if coolant needed top up yesterday. Not unduly low.... put a bit in... spilled a little...
27th Aug 2020 2:08pm |
So is the best way to inspect to drive on ramps and remove under tray ?
27th Aug 2020 4:03pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 575 |
When I did my SC I just put it into off road height, a couple of axle stands and there is loads of room to get under.
27th Aug 2020 5:43pm |
I’m hoping it’s not water pump. Not keen on it being radiator, but that said... it’s probably the original one and getting ready.... 2011 Range Rover Vogue SE 4.4 TDV8
27th Aug 2020 6:01pm |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
I normally put mine into extended height mode which gives plenty of room to remove the under tray and work on most components under the vehicle.
28th Aug 2020 5:58am |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
Access is fairly easy, I always put axle stands and I don't trust the suspension going back to access mode.
28th Aug 2020 7:02am |
jordon0 Member Since: 06 Mar 2016 Location: derbys Posts: 53 |
thought my coolant was old looked like that
28th Aug 2020 7:06am |
