![]() | Home > Technical (L322) > Tdv8 whistling turbos |
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 ![]() ![]() |
Without hearing i really dont know but make sure you do not have a boost leak from a split intercooler hose etc... If you do generaly youll get black smoke and reduced performance if it is bad enough ... your turbo can also overspeed and fail which is why i say check it out
Oddvar.L Member Since: 22 Aug 2020 Location: Nordland Posts: 34 ![]() ![]() |
Thank You for Your response.
To be honest with you I've never been in another TDV8 either which I'd like to do.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 905 ![]() ![]() ![]() |
Are you sure it's the turbos?
Pretty sure. Should have generated this sound at warious speeds with low throttle setting then.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 754 ![]() ![]() |
I would say don't panic too much unless the noise gets worse quite quickly or you start to get "restricted performance" or fault messages.
Thank You for reply. No black smoke or any signs of reduced performance. Will check intercooler/turbo hoses as a matter of course. Is there any tendenses for witch hoses usualy goes wrong? |
