Home > Technical (L322) > Air conditioning fan not working
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
Hi,all hope you are safe and well ,my electric fan for the air conditioning is not coming on is there a fuse or relay I could check I cannot seem to find any information on it the fan spins freely and is smooth when spun by hand,help much appreciated
Post #565458 25th Aug 2020 3:59pm
Try Fuse 12 10A and Fuse 34 7.5A on the front fuseboard for starters. Thumbs Up
Post #565472 25th Aug 2020 6:05pm
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
What engine? Mine is also not working :/ Funny point is: I can spin it via Tester with E53, there is stage 1 and stage 2 that i can switch, only one stage spina the fan. Sadly for the TD6 you have to buy the whole fan. Anyone any tipps? Thanks!
Post #565528 26th Aug 2020 10:32am
cowman
Tried the fuses both ok mine is a td6 not sure what to check now
Post #565568 26th Aug 2020 3:08pm
clemenz
Same here! Do you have any tester?
Post #565569 26th Aug 2020 3:14pm
cowman
I have just scanned it and it is coming up with 0480 fault code
Post #565574 26th Aug 2020 4:17pm
https://partsavatar.ca/p0480-obd-ii-troubl...ay-harness
Post #565584 26th Aug 2020 5:28pm
cowman
Does anybody know the location of the temperature senser
Post #565769 28th Aug 2020 1:19pm
The ac ambient temperature sensor is clipped to the rear of the front grille, lhs.
Post #565808 28th Aug 2020 8:17pm
clemenz
I have the same problem, A/C fan not starting when i turn on the A/C.
Fuses - Checked and working
Refrigerant Pressure sensor - Working
Compressor clutch - working
Ambient temperature sensor - working
Aircon itself - Regased this year after condensor change, working strong.
Activating the fan via Hawkeye - Yes, working
Tried an alternative fan yesterday, still not working when engine is idling and a/c is on. Only activation via tester.
I notice that the a/c is missing air flow when stopping on red light, cold air is not so cold then.
When i start to drive it’s getting colder.
Anyone any tipps? Thanks!!
Car is TD6 MY06.
Post #567438 19th Sep 2020 7:49am
