Home > Technical (L322) > Air conditioning fan not working |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 |
Hi,all hope you are safe and well ,my electric fan for the air conditioning is not coming on is there a fuse or relay I could check I cannot seem to find any information on it the fan spins freely and is smooth when spun by hand,help much appreciated |
25th Aug 2020 2:59pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3971 |
Try Fuse 12 10A and Fuse 34 7.5A on the front fuseboard for starters. |
25th Aug 2020 5:05pm |
Tried the fuses both ok mine is a td6 not sure what to check now |
26th Aug 2020 2:08pm |
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 182 |
Same here! Do you have any tester? |
26th Aug 2020 2:14pm |
I have just scanned it and it is coming up with 0480 fault code |
26th Aug 2020 3:17pm |
26th Aug 2020 4:28pm |
Does anybody know the location of the temperature senser |
28th Aug 2020 12:19pm |
The ac ambient temperature sensor is clipped to the rear of the front grille, lhs. |
28th Aug 2020 7:17pm |
I have the same problem, A/C fan not starting when i turn on the A/C.
19th Sep 2020 6:49am |
