Home > Technical (L322) > IID suspension calibration
All, I noticed that my N/S height was low compared to the other 3 corners, so I figured I would run through the guided calibration process.
All seemed well but when I got the offending corner, the height always drops, despite me using the "up" arrow! The "down" arrow also drops the corner Whistle
If I put the car in "off road" height, the N/S height rises..........
Any thoughts?
Cheers Got - 2017 SDV8 Autobiography in Loire Blue
Post #565342 24th Aug 2020 1:07pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Do the other corners go up and down as you'd expect? Last time I did this was before the guided calibration was available so not familiar with the UI. Can you still see the raw sensor values? Just wondering if it could be a dodgy sensor? Monitor the sensor values as it goes from entry -> normal -> off road heights and see if it tracks correctly. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #565348 24th Aug 2020 1:54pm
Screenshots from the 3 height positions. Each corner lifts and drops but the N/S rear is consistently around 25-30mm lower than the other 3.
Post #565390 24th Aug 2020 8:03pm
Well just to put this to bed, it mysteriously resolved itself!
Oh the joys Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #566082 1st Sep 2020 6:53pm
