![]() | Home > Technical (L322) > IID suspension calibration |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 ![]() ![]() ![]() |
Do the other corners go up and down as you'd expect? Last time I did this was before the guided calibration was available so not familiar with the UI. Can you still see the raw sensor values? Just wondering if it could be a dodgy sensor? Monitor the sensor values as it goes from entry -> normal -> off road heights and see if it tracks correctly. 2016 Skoda Octavia VRS Estate
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6746 ![]() ![]() ![]() |
Screenshots from the 3 height positions. Each corner lifts and drops but the N/S rear is consistently around 25-30mm lower than the other 3.
Well just to put this to bed, it mysteriously resolved itself!
