Home > Technical (L322) > tdv8 4.4 low fuel warning
paulwlincs
I'm sure this has been said before but , i was towing my caravan down to South coast last year when the fuel gauge dropped like a stone to empty accompanied by the dreaded bong and amber warning . I knew i had at least 3/4 of a tank so we pressed on and 80 miles later the whole car started shaking and slowing down . The ecu shut's the engine down which meant recovery to our destination . On arrival the gauge went back to normal and stayed like that until the day we set off for home , you couldn't make it up Big Cry .
So recovery home with caravan , i set about looking inside the tank for the expected crimp repairs on the senders but they had been done . It soon became obvious that the problem was inside the moulded connector on the tank so i picked it apart , cleaned it up and packed with dialectic grease , reassembled and it's been fine since .
So fellow Rangie members don't ignore the fuel warning it bites Embarassed . 2011 tdv8 4.4 vogue Santorini black
Post #565013 19th Aug 2020 3:35pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
So your saying the ECU refused to fire up the engine when it had 3/4 of tank of fuel in it?
Failing to understand what towing had to do with it.
Not being a diesel expert is it to protect from air in fuel system like direct injection petrols?
Weird how it worked once you got to the destination.
Post #565039 19th Aug 2020 7:44pm
paulwlincs
The ecu thinks the engine is running out of fuel , so it starts to shut down by stuttering the engine and if it carries on being run it stops altogether. The towing was nothing to do with the issue just an inconvenience .
The point i was making was don't just think it's a fuel level warning and ignore it , when the ecu has had enough you can be stranded at the worst possible time . 2011 tdv8 4.4 vogue Santorini black
Post #565055 20th Aug 2020 6:28am
