Home > Technical (L322) > TD6 dash bong when accelerating from cold
Roi354
United Kingdom 2005 Range Rover Vogue Td6 Buckingham Blue
I live on a main-ish A road and occasionally when I leave I have to accelerate harder than I'd like with a cold engine/box.
On occasion I'll get a bong but no error or warning to indicate what the problem is. It'll continue to drive fine after this event (barring a puff or two of smoke).
Is this normal behaviour?
Post #564557 14th Aug 2020 11:11am
V8Simon
United Kingdom 2004 Range Rover Vogue SE Td6 Java Black
My 2003 TD6 does similar but I've presumed its because its at the lowest setting on the suspension which has a 25mph max speed and it takes a min before it triggers the pump to raise up to normal height???? 2004 Vogue SE TD6
(Also a LR 90 V8 & RRS, just because)
Post #565005 19th Aug 2020 3:45pm
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
I notice the same sometimes, also when i need to push it hard it has one gear shift problem from 1-2, second attempt is fine then. Definitly no bong because of suspension, only accoustic allert no message, no failure in ecu! It‘s mysterious!
Post #565067 20th Aug 2020 11:08am
i believe that there are gear restrictions until the engine and gearbox is warmed up and the oil is flowing..
this could account for the 'bong' on a hard acceleration when cold. ... - .- -.
Post #565071 20th Aug 2020 12:11pm
