![]() | Home > Technical (L322) > Transmission fault |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
Do you have a list of the codes it’s throwing up, that will help point in the right direction.
Biggp Member Since: 15 Aug 2020 Location: Dunfermline Posts: 7 ![]() ![]() ![]() |
Thanks for reply.
Not unless you have a code reader like an IID Tool. |
Can you recommend a good one ? There’s so many on market and heard some are no good. Think I need to invest as I’ve had a few problems lately |
The Gap IID Tool is the one a lot of us use on here, it allows you to change most of the different computers on the range rovers |
Thanks I’ll have a look for one now 👍 |
fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124 ![]() ![]() ![]() |
Could be gearbox oil exceeding 140°c and triggering a protection mode that forces revs up by limiting the available gears so that oil pumps faster through the oil cooler. As others have mentioned the GAP IIDTool is the one to go for as it allows you to drive the vehicle and monitor up to 8 live values. "Gloria" 2002 L322 Voguish V8 LPG - carcass "Jessica" 1996 Disco 1 300 TDi Auto "Harriet" 1994 Disco 1 300 TDi Manual - Gone "Daisy" 1992 Disco 1 200 TDi Manual - Gone |
Thanks I’ve had a look for one I saw the IID BT around £450 think this is the one that is vin locked is this the best or does anybody have a link they could post it would be appreciated and I know I’m buying the correct one
