Home > Technical (L322) > Transmission fault
Biggp
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Transmission fault
My RR has a fault that one minute it was fine next it had developed this, it starts fine then dashboard has HDC fault, Handbrake fault, suspension lowered, only selected gears available. It will drive but only in 3rd gear or reverse even command shift will stay in 3rd that's in hi/low ratio. I'm away from home just now so had local garage plug it in and they are saying there is no communication between any of the modules. they tried to clear but it won't let it as there is a engine system fault showing that has become a permanent fault which ive had for some time and cant get resolved after lots of money throwing parts at it I believe it is a boost fault but replaced all the common things and turbos. Please help if you can thanks in advance.
Graeme
Post #564675 15th Aug 2020 3:13pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Do you have a list of the codes it’s throwing up, that will help point in the right direction.
There are many things that can cause comms issues between modules
Post #564676 15th Aug 2020 3:20pm
Biggp
Thanks for reply.
I will get them from the garage maybe tomorrow.
Is there any other way of getting the codes via the dash?
Cheers
Post #564677 15th Aug 2020 3:34pm
lighthouse
Not unless you have a code reader like an IID Tool.
Post #564680 15th Aug 2020 4:29pm
Biggp
Can you recommend a good one ? There’s so many on market and heard some are no good. Think I need to invest as I’ve had a few problems lately
Post #564681 15th Aug 2020 4:40pm
lighthouse
The Gap IID Tool is the one a lot of us use on here, it allows you to change most of the different computers on the range rovers
Post #564683 15th Aug 2020 5:02pm
Biggp
Thanks I’ll have a look for one now 👍
Post #564684 15th Aug 2020 5:25pm
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
Re: Transmission fault
Graeme
Could be gearbox oil exceeding 140°c and triggering a protection mode that forces revs up by limiting the available gears so that oil pumps faster through the oil cooler.
As others have mentioned the GAP IIDTool is the one to go for as it allows you to drive the vehicle and monitor up to 8 live values. "Gloria" 2002 L322 Voguish V8 LPG - carcass
"Jessica" 1996 Disco 1 300 TDi Auto
"Harriet" 1994 Disco 1 300 TDi Manual - Gone
"Daisy" 1992 Disco 1 200 TDi Manual - Gone
Post #564698 15th Aug 2020 7:09pm
Biggp
Thanks I’ve had a look for one I saw the IID BT around £450 think this is the one that is vin locked is this the best or does anybody have a link they could post it would be appreciated and I know I’m buying the correct one
Thanks again
Post #564706 15th Aug 2020 7:51pm
