Home > My Range Rover > Project P38 - Monte Carlo Blue 4.6 Vogue..
Page 5 of 6 <123456>
MonteCarlo
"EAS calibration"
After a few jaunts it became apparent it had a rather drunken lean to the left Whistle
Check this out..
See the difference LOL Rolling with laughter
Doing the this job is very simple on the P38..
I had to sacrifice one of my broom handles to make the calibration blocks for all the heights. Mr. Green
You need the free RSW software and a cable!
process goes like this Put the suspension on high, jack it up a bit more (one jack on the front crossmember just in front of the radiator, the other one under the towbar) and put your blocks in, starting with the highest. Release the jacks, then poke the rocker on the dash for access height. so it drops down and sits on the blocks. Open the door to inhibit it. Go to the Heights tab in the software and click, Get Sensor Heights, make a note of the readings for each corner. Go to the Calibrate tab, click Read All and you'll see two sets of numbers. Top ones are what it is programmed to now and the bottom set of numbers will show the same numbers. Change the bottom set to what you have just noted down and click Write. If you then click on Read All again, you'll see that the top set, the programmed heights, will have changed to what you have just input in the bottom set.
Jack up, take your blocks out, fit the next set (Standard) and do the same thing for each height setting. You can only change one height at a time, you can't amend more than one set of numbers and then Write the whole lot. The software will try to always put the car back to standard height so make sure it is sitting on the blocks and the door is open before reading the existing heights.
result
Much better! Mr. Green
Not leaning like a drunk Mr. Green MY2001 Range Rover P38 Vogue 4.6
MY2005 Jaguar S type 3.0 SE
MY2000 Land Rover Discovery II TD5
MY1987 Bentley Turbo R "project"
MY1977 Rolls Royce Silver shadow. "project"
Post #564409 12th Aug 2020 11:02pm
MonteCarlo
A nice Oil change next on the cards..
My potion on choice! Mr. Green
Oil drain plug is 15mm, I've changed the oil many times hence the old oil looking rather new!
New filter primed up with some fresh oil
And spun on hand tight Mr. Green
New 10w60 poured in.. Bow down
And she's a happy bunny!
sounds sublime!!
Couldn't help but add a little badge!!
just to finish off the service Bow down
Mr. Green
A nice new set of Gas struts for the tailgate were added to, just to stop it decapitating shorter people!
Old ones off.
New ones on!
It doesn't smack you on the noggin now! Mr. Green MY2001 Range Rover P38 Vogue 4.6
Post #564412 12th Aug 2020 11:27pm
MonteCarlo
"self reminder
Rust prevention
Exhaust
Pulley fix
Detailing
Interior clean
etc
Just a reminder next time I update!!
SO much to come, don't want to post the same thing twice! Rolling with laughter MY2001 Range Rover P38 Vogue 4.6
Post #564414 12th Aug 2020 11:40pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
looking very good keep up the good work Thumbs Up
Post #564513 13th Aug 2020 6:17pm
dhallworth
Looks like I'm not the only one on here with an obsession for P38's then Smile
I had a 2002 Oslo Blue Vogue SE which I wish I'd never sold.
The two I've kept are a matching pair of 2002 Vogue SE's in Alveston Red. The picture of the pair together was taken in February when both were filthy.
The one on the left has since had the side steps removed, some cosmetic touches done and a brand new V8 Developments engine with top hat liners, a torquemax camshaft, bigger valves, and gas flowed heads. It's made a noticeable difference to the car when compared with the other one.
The one on the right hasn't need much more then minor fettling and cleaning. Smile
We've still got 2 1997 4.6 HSE's that I'm going to be rehoming before long. I don't have the time to look after 4 P38's and the other cars we have so I'll keep the 2 Vogue SE's.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #564556 14th Aug 2020 9:43am
kevinp
What a brilliant story. Loved reading it all.
Post #564562 14th Aug 2020 12:18pm
MonteCarlo
David.
What a nice Collection you have there! Thumbs Up
A lucky man, I don't think I could judtify another P38 lol but I'd love a late VSE
Your Alveston red pair look the nuts.. Bow down MY2001 Range Rover P38 Vogue 4.6
Post #564581 14th Aug 2020 4:15pm
MonteCarlo
Thank yo very much. Thumbs Up MY2001 Range Rover P38 Vogue 4.6
Post #564582 14th Aug 2020 4:17pm
MonteCarlo
"Rust Prevention"
Rust and P38 seldom ever come together, however mine had a slight bit of surface corrosion on the rear chassis legs nothing of an concern Whistle
She was a pembroke/swansea car her previous life so some salt corrosion was to be expected..
The underside was prepared with a wire brush, to remove any loose material and the rest treated with Hydrate 80..
This in theory neutralises the rust the next potion is a rust resistant barrier..
Painted on well!
and then Undersealed!
Thats it to be fair regarding rust LOL Rolling with laughter
The front was treated to a pressure wash, and clean to remove the caked on MUD that can cause corrosion.
During
Done!!
You'll note these updates are slighty mixed up!!
More to come! Bow down MY2001 Range Rover P38 Vogue 4.6
Post #564586 14th Aug 2020 4:35pm
MonteCarlo
The rear cross member that houses the towbar was a mush mash of different colours
It looked a tad unsightly..
All crud was removed.
And treated.
Not concourse but we'll get back to it!!
Post #564588 14th Aug 2020 4:43pm
MonteCarlo
Thank you very much!
more to come Sheep MY2001 Range Rover P38 Vogue 4.6
Post #564592 14th Aug 2020 5:04pm
MonteCarlo
More of a Mixed bag this update.. Razz
A known but not very common issue is the sunroof glass separating from the metal frame due to corrosion and allowing water under the seal and onto the inside of the glass..
Which is rather annoying.. Laughing
The issue can be thought of early as "condensation" however it was dripping onto my gearlever, and centre console so something had to be done! Mr. Green
Thinking initally it was the seal at fault I had a quick look and while it was green with dirt, it was still soft and wasn't falling apart.
I therefore treated with to a gentle clean with some Vinyl an rubber care.
The rails ere also greased your poor motor will love ya for this!!
drier than a bone before!
Much betterter!! Wink
Anyway...
On to the water ingress.
There was a suspicious lump near the rear of the sunroof.
turns out it was rust..
SO i pulled the seal off and treated the rust, then at as a didtch effort I forced Silicone sealant into the gaps..
And then hammered the seal back on, with the assistance of some clamps!
I also cleaned and polished the roof! Wink
Verdict is no more leakage!! Mr. Green Thumbs Up MY2001 Range Rover P38 Vogue 4.6
Post #564594 14th Aug 2020 5:33pm
MonteCarlo
Chassis shenanigans.. Bow down
No rust just dirt, being she is used though all weathers I'd like to keep it that way Wink Thumbs Up
Before!
And a few afters..
The Potions of choice was Dinitrol a whole heap of dinitrol Thumbs Up
Looks better, and will stay pretty Wink Mr. Green Thumbs Up
The Sills too..
Don't forget them!
You'll note the Dinitrol dried to a Matt colour, and there are 1k miles between pics!! Wink
I also took out the rubber bungs and put some waxoyl inside
She ain't gonna rust!! Mr. Green MY2001 Range Rover P38 Vogue 4.6
Post #564596 14th Aug 2020 5:45pm
mjdronfield
I must admit, I skipped the P38 and got a Discovery 2 after my classic, and before the L322. Couldn’t fault the Disco to be honest.
But I think the P38’s are finally coming into their own now.
Lovely looking cars in this thread.
Well done Gents.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #564600 14th Aug 2020 6:10pm
MonteCarlo
Thank you..
The P38 was/is much maligned..
Their reputation isn't deserved IMO as they aged they became almost worthless and all kinds bought 'em..
Neglected examples flooded the market and gave them a bad name, IMO
Parts are cheap if needed, easily 1/2 the price compared to her Younger siblings Mr. Green Bow down MY2001 Range Rover P38 Vogue 4.6
Post #564611 14th Aug 2020 8:32pm
