Home > My Range Rover > Project P38 - Monte Carlo Blue 4.6 Vogue..
Page 6 of 6 <123456
MonteCarlo
Time for an update on the old girl Wink
The first major thing that has changed over the past few months has been the exhaust, after 19yrs and several bad repairs the original system was very worse for wear and to be fair it sounded quite bad...
Removal of the old system required the use of my angle grinder more than anything else!
No sockets required Thumbs Up
After much faffing around with the mounts it came free!
To be fair after seeing it off the car I did wonder how it managed to stay together!
The only slight complication was dirt/rust on the chassis behind the mufflers, which is quite common on P38s. Bow down
It looked worse than it was!
I wire brushed it off and wiped it down to see what condition the metal was in.
Thankfully it was in good nick, a coat of hammerite kurust and some waxoyl should keep it at bay for a while Mr. Green
Much better!
And while the centre muffler was out of the way the chassis was painted!
Before and after as usual Wink
After Wink
Moving on!
The exhaust replacement next, in the form of a nice Janspeed stainless unit, after much faffing and swearing it was fitted, the only real issue of the day was working on gravel Big Cry
The first oval hole and shotgun tip out the back Wink
2nd one fitted
Of course I polished the unit underneath too!
After a quick rub down!
And finally!!
Some better shots of the unit on the car! Laughing
Much better! Mr. Green
Sounds the part too!!
 MY2001 Range Rover P38 Vogue 4.6
MY2005 Jaguar S type 3.0 SE
MY2000 Land Rover Discovery II TD5
MY1987 Bentley Turbo R "project"
MY1977 Rolls Royce Silver shadow. "project"
Post #570244 18th Oct 2020 7:33pm
MonteCarlo
Exhaust Part 2 Mr. Green
When you have an exhaust made of 304 stainless it is ride not to make it sparkle, especially when it hangs down under the car Laughing
Some before shots! Laughing
And finally some afters! Wink
Might of got a bit carried away with that job, over an hour with autosol, you be the judge lol Rolling with laughter
Whistle MY2001 Range Rover P38 Vogue 4.6
Post #570248 18th Oct 2020 7:39pm
Page 6 of 6 <123456
