Home > Technical (L322) > On the scrounge
noworries4x4
On the scrounge
Does any one in South Devon have an OBD device that I can pair a new steering sensor with on Sunday, The steering column was sent away for repair and came back with the steering angle sensor smashed, fitted a new one but its can bus id needs pairing with the abs ecu and others as its information is used for traction control hill descent control abs etc. If everything is under control you are not going fast enough.
MY 16 Discovery 4 Commercial Workshop and Escort Vehicle
MY 12 Full Fat TDV8
1952 Series 1 80" 3ltr 6cyl
Post #564378 12th Aug 2020 9:15pm
noworries4x4
All sorted, my neighbour's son brought home his workshops Mac Tools touch screen obd tool, it did a vehicle wide search and repaired things it could see that were not right, don't quite know what it did but no faults when steering anymore. If everything is under control you are not going fast enough.
MY 12 Full Fat TDV8
Post #565025 19th Aug 2020 7:25pm
