![]() | Home > Maintenance & Mods (L405) > Help! Trying to upgrade my 2014 w/ traffic sign & Lane d |
Mark1107 Member Since: 20 Oct 2014 Location: Los Angeles Posts: 106 ![]() ![]() ![]() |
Fixed it. I ordered the wrong button!
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 ![]() |
This is cool.
1. GAP iid tool.
5. Follow GAPs website for changing the ccf files full access to ccf files, Patrick Meiiluer at GAP will enable your tool to do this. 6. Enjoy!
If you have the two prong you swap out plugs here....the black plastic trim between dashboard and door
This is the mirror you need. It’s available on eBay.
The one I have says DK5217E67CA.
steve56 Member Since: 13 Jun 2020 Location: colorado Posts: 13 ![]() ![]() ![]() |
You have to look and see if your mirror has the little black camera attached?
Are any of the attached pictures showing the camera?
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 339 ![]() ![]() ![]() |
I'm interested in this project (for my 2015 AB). I'm sure I have the camera, as I have High Beam Assist. The problem arises with the switch; I have deployable side steps fitted so the switch position is taken by them.
Miller you can check the PN of the rear view mirror (it is on the back of the mirror) and post it. Maybe it helps... |
jack - I'll have a look later.
Pull the black plastic shroud around your mirror camera. You will see if it has a camera . Dpla 17e68 hc or gc is the serial number on the back of the mirror.
