Home > Maintenance & Mods (L405) > Help! Trying to upgrade my 2014 w/ traffic sign & Lane d
Mark1107
United States 2013 Range Rover HSE 5.0 V8 Fuji White
Has anyone done this?
If so can you help me?
1. GAPs website has the steps and part numbers.
2. I try to plug in the lane departure button on the lower dashboard and all of the plugs are different and missing from my wiring loom.
3. Trying to find the high line mirror w/ldw and tsr is a nightmare.
Post #563979 8th Aug 2020 6:59pm
Mark1107
Fixed it. I ordered the wrong button!
Post #563984 8th Aug 2020 10:56pm
jackcramerr
This is cool.
Can you please list the prerequisites and the part number to carry this out ?
Post #563998 9th Aug 2020 8:48am
Mark1107
1. GAP iid tool.
2. Rear view mirror with an actual camera high line DPLA 17E678 HC or GC (the key thing is H or G the letter after that doesn’t matter.) (eBay has both but it takes ALOT OF DETAILED SEARCHING) or order new for about $600 USD or cheaper with a parts supplier friend.
3. Pull off your lower dashboard trunk release button and see if you have the two prong green and grey plug or one prong grey plug.
4. Get the two prong or one prong trunk release button with the lane departure symbol on it. (EBay carries both for about 80-100 USD)
4.A pull the black plastic trim that sits between the dashboard and the door. There is a green plug you swap out if you have the two pronggreen and grey plug or just plug and play the grey one prong plug without pulling the black plastic trim.
5. Follow GAPs website for changing the ccf files full access to ccf files, Patrick Meiiluer at GAP will enable your tool to do this.
6. Enjoy!
Post #564051 9th Aug 2020 6:54pm
Mark1107
If you have the two prong you swap out plugs here....the black plastic trim between dashboard and door
Post #564053 9th Aug 2020 6:59pm
Mark1107
This is the mirror you need. It’s available on eBay.
Post #564054 9th Aug 2020 7:01pm
jackcramerr
The one I have says DK5217E67CA.
So is TSR now working for you?
Did you simply pull the trunk/boot button out?
Also for GAP tool, can I ask someone for a favour and use his tool or do I need to purchase it?
Post #564114 10th Aug 2020 2:40pm
steve56
United States 2015 Range Rover Autobiography 5.0 SC V8 Balmoral Blue
You have to look and see if your mirror has the little black camera attached?
The GAP only works on locked VINS so you have tobuy your own.
Yes the button pops out with a simple 5 dollar trim tool or any flat head screw driver.
Post #564154 10th Aug 2020 8:05pm
jackcramerr
Are any of the attached pictures showing the camera?
Post #564186 11th Aug 2020 11:43am
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I'm interested in this project (for my 2015 AB). I'm sure I have the camera, as I have High Beam Assist. The problem arises with the switch; I have deployable side steps fitted so the switch position is taken by them.
I'm wondering if it can all be done without the switch. This would mean that the system cannot be disabled "in-flight".
Post #564188 11th Aug 2020 11:48am
jackcramerr
Miller you can check the PN of the rear view mirror (it is on the back of the mirror) and post it. Maybe it helps...
Post #564203 11th Aug 2020 1:47pm
millerj90
jack - I'll have a look later.
Many Thanks
Post #564208 11th Aug 2020 2:14pm
Mark1107
Pull the black plastic shroud around your mirror camera. You will see if it has a camera . Dpla 17e68 hc or gc is the serial number on the back of the mirror.
They sell a button with deployable side steps dimming hatch release and ldw. You have to search for it on ebay or get duckworth to help you.
Post #564225 11th Aug 2020 5:58pm
Mark1107
Active high beam assist mirrors dont work with tsr and ldw. You have to get the highline mirror listed on gaps website. I screenshotted it above.
Pic of ahba mirror
Post #564227 11th Aug 2020 6:19pm
Mark1107
Heres a pic of button with:
Hatch release
Lane departure
Side step rails
Dimmer switch
Post #564230 11th Aug 2020 7:08pm
