Home > Technical (L322) > Battery drain |
A.Pires Member Since: 02 Dec 2016 Location: Seixal Posts: 145 |
Why in my 2002 td6 L322 the battery drain so fast? |
10th Aug 2020 3:18pm |
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 |
Maybe left the crystal ball plugged in??? 2006 4.2 SC |
10th Aug 2020 5:04pm |
Crystal Ball??? |
10th Aug 2020 5:13pm |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
I have just been through this - see ; https://www.fullfatrr.com/forum/topic55802.html There are also other threads on the subject - do a google search to find them & have a read up. Then, you can start making you way through the possible causes. However, the first things to check are the alternator/charging & the battery - Range Rovers really do need a very good battery. Good luck. 2003 Range Rover Vogue TD6 |
10th Aug 2020 6:13pm |
Thank you very much Brian |
10th Aug 2020 7:17pm |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 |
Make sure something obvious like the leads are tight to the terminals, battery on mine drained regularly, just couldn’t get leads tight , bit of copper wire sorted it, that was five years ago, still going strong. |
12th Aug 2020 1:28pm |
V8Simon Member Since: 18 Dec 2019 Location: North Wales Posts: 20 |
My experience had several points to it over a 7 month timescale. When I bought it the battery light would come on, flickering mainly when on runs in the first week of ownership, culminating in a recovery home on the back of a AA lorry when it died completely on the M6.
19th Aug 2020 3:03pm |
