Home > Technical (L322) > TDV8. No revs and won't drive or reverse.
suffolkpunch
United Kingdom 2006 Range Rover Vogue SE TDV8 Tonga Green
I have a intermittent fault on my L322 Tdv8. The fault is becoming more frequent now. When starting up sometimes I will have no revs and no response when selecting drive or reverse. It comes up with transmission fault and HDC fault on dash. The other day after turning on and off a few times I got drive but revs still low and airbags went down on suspension. could only do about 25mph. pulled over and left for five minutes started again and everything was ok and had full revs, drive and reverse. Any info would be much appreciated.
Post #564038 9th Aug 2020 3:25pm
DrRob
Fault codes read?
Suggest investing in a diagnostic like the GAP IID Bluetooth and then you have a fighting chance of working it out.
How old is the battery? Are the clamps tight on it? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #564039 9th Aug 2020 3:36pm
