![]() | Home > Technical (L405) > restricted performance |
Gazm007 Member Since: 22 May 2019 Location: Surrey Posts: 37 ![]() ![]() ![]() |
thats exactly what i thought Craig! |
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 ![]() |
It this theory valid that a clogged dpf can cause engine to heat and thus head gasket can get damaged? |
thanks Craig - i'm pretty sure that was the same fault that came up on mine today - actuator. i will mention it to them when i bring it in. i'm not planning on driving it until then |
Alpinebullet Member Since: 23 May 2020 Location: Saddleworth Posts: 12 ![]() ![]() ![]() |
Evening all. Unfortunately, I also got the Restricted Performance message appear on the dash earlier today with the accompanying drop off in power as I accelerated on to a dual carriageway. Car is a 2013 SDV8 and I’ve only had it a couple of weeks. |
Update on the repair. Picked the car up from my local indy workshop last Friday. The fault was traced to a boost pressure sensor which had come off a turbo hose. All replaced and fingers crossed that’s the end of it. Very happy with the service I received from AJR Land Rover in Oldham. |
