Home > Technical (L322) > Heat Shield Rattle / Noise
HillBillyGash
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Zermatt Silver
The heat shield above the rear prop on my TDV8 is rattling..... going to remove or try and refix. Any reconditions of where to source a new one? The sheild seems to be rattling due to the aluminium layers separating? Any suggestions much appreciated
Post #563344 2nd Aug 2020 2:26pm
sometimes you can bend it out of the way... ... - .- -.
Post #563348 2nd Aug 2020 2:48pm
Weegie
If it is the layers separating, could you drill it and put a couple of small nuts and bolts to pull it together? John
GAP iiD BT
Post #563350 2nd Aug 2020 3:08pm
HillBillyGash
Hi, thanks for your responses - was thinking about gently drilling and pop rivets!!
I had some brake pipes replaced and the Indy bent the shield and made a bit of a mess of it tbh and it hasn’t been the same since🙄
Post #563358 2nd Aug 2020 4:01pm
