![]() | Home > General (L405) > 2013 l405 5.0 L Supercharged with high milage |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 ![]() ![]() ![]() |
Paul
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
The timing chain Tensioners and guides are an issue and its an expensive job so check if that’s been done.
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
120k Miles isn't really high mileage.
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 123 ![]() ![]() ![]() |
Thank you all for your replies
The parts including tensioners, guides, chains, all the gaskets, water pump (good idea to replace while its apart if it hasn’t been done), accessory and supercharger belts are about £900. Its a good idea to change the supercharger isolator and pulley bearing and change the supercharger oil while it’s apart too - about £200 in parts.
Thank you WB 2015 AB 5.0 Supercharged
johnf Member Since: 16 Nov 2012 Location: Nottinghamshire Posts: 84 ![]() ![]() |
I'm up to 137,000 miles (220,000km) in my 2013 supercharged and have only had one serious blip at about 95,000 miles - needed a new hydraulic tensioner and shortly afterwards a new fuel injector - total cost just over £5,000 of which Landrover paid about half. Always used main dealer for maintenance hence high price (but also, I guess, Landrover contribution).
Hi johnf
